Maximum bending moment and maximum deflection of the spring?
To determine the maximum bending moment and maximum deflection of a coil spring under compression, it is essential to recognize that the loading does not produce a bending moment, as the load is applied vertically. Instead, the maximum deflection occurs when the coils touch, and the spring is fully compressed. The analysis of such springs involves torsion rather than bending, and relevant formulas can be found in resources like "Shigley’s Mechanical Engineering Design" or "Roark’s Formulas for Stress and Strain." Understanding the distinction between bending moments and torsional loading is crucial for accurate calculations. Proper application of these principles will lead to the correct assessment of spring behavior under load.
metalsunsuccess1
TL;DR Summary
How do I find the maximum bending moment and maximum deflection of the spring?
How can I find the maximum bending moment and maximum deflection for a spring?
It would be very helpful if you could explain the specific procedure and formula in an easy-to-understand manner.
that's all, thank you very much.
What kind of spring is this?
Thank you for your reply.
This assumed mechanical spring is a coil spring, and the lower part is placed on a table (not fixed), and a concentrated load is applied from above in the compression direction.
Thank you.
Thank you.
So how is there a "bending moment"? The loading you described wouldn't produce one.
The "maximum deflection" of a compression coil is when the clearance between the coils is zero.
Helical springs subjected to compression are calculated for torsion. You can find the formulas for example in "Shigley’s Mechanical Engineering Design" or in "Roark’s Formulas for Stress and Strain".
Likes cherish, Chestermiller and berkeman
It looks like you saw the units [N.m] or [lbf.ft] somewhere and thought it was bending moment, but springs are usually loaded in pure torsion, which uses the same units, but the meaning is completely different.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
