Maximum bending Moment and Maximum Shear Stress Question
The maximum bending moment and maximum shear stress can be considered in absolute terms when determining design parameters. For example, a bending moment of -400 kNm and +300 kNm indicates that 400 kNm is the maximum absolute value, but the sign is crucial for understanding beam curvature. The same principle applies to shear forces; the larger magnitude should be used for maximum calculations. It is important to consider both the absolute values and their signs to ensure proper beam design and analysis. Understanding these concepts is essential for effective structural engineering.
coolguy16
Is the maximum bending moment and maximum shear stress an absolute value? For example, when drawing out a bending moment diagram say if I get -400 kNm at one point and 300 kNm at a different point. If these values are the maximum/minimum points on my diagram would 400 kNm be considered as a maximum bending moment? Does the same method apply for shear force also?
Thanks
You wouldn't want to design a uniform beam for +300 moment when you have a -400 moment, so in that sense, use the absolute value for the max. But plus and minus moments tell you about the curvature of the beam (concave or convex) so you can't just ignore the signage . Same for shear in terms of using the larger magnitude if you are looking for the max
Likes coolguy16
Ok perfect. Thanks so much.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
