Maximum exhaust velocity for a De Laval nozzle
The discussion focuses on calculating the maximum exhaust velocity for a De Laval nozzle using Bernoulli's equation for compressible gases. The user starts by assuming the velocity at the exit is zero and derives several equations relating pressure and Mach number. Key equations include the relationship between pressure ratios and Mach number, particularly at the throat where Mach equals one. The user aims to find the value of Mach and the ratio of pressures to determine the exhaust velocity. Ultimately, the goal is to calculate the pressure ratio needed to find the maximum exhaust velocity.
happyparticle
Finding the maximum exhaust velocity for a De Laval nozzle in term of ##c_s##
##c_s = \sqrt{\frac{\gamma P_o}{\rho_0}}##
##M = \frac{u}{c_s}##
##\frac{P}{P_0} = (\frac{\rho}{\rho_0})^\gamma##
Here is what I did so far.
First of all, at ##P_0## (the opposite end of the exit), I supposed ##u_0 = 0##. (Is it correct?)
Hence, using Bernoulli's equation for a compressible gas.
##\frac{\gamma}{\gamma -1} \frac{P_0}{\rho_0} = \frac{u^2}{2} + \frac{\gamma}{\gamma -1} \frac{P}{\rho}##
##\frac{P_0}{\rho_0} = \frac{u^2}{2} (\frac{\gamma - 1 }{\gamma}) + \frac{P}{\rho}##
Then, using the relevant equations and with a little algebra.
##\frac{c_{s_0}^2}{c_s} = \frac{M^2}{2} (\gamma -1) + 1##
With the help of the third relevant equation I get:
##\frac{P_0}{P} = [\frac{M^2}{2} (\gamma -1) +1]^{\frac{\gamma}{\gamma - 1}}##
Also, knowing that where the cross-section is the lowest, M =1.
##\frac{P_0}{P} = [\frac{1}{2} (\gamma -1) +1]^{\frac{\gamma}{\gamma - 1}}##
Then, I would like to have the ratio between the pressure at #M=1# and at the exit.
##\frac{P_0}{P} \frac{P_1}{P_0} = \frac{P_1}{P}##
After some algebra I get:
##(\frac{P_1}{P})^{\frac{\gamma -1}{\gamma}} = M^2 (\frac{\gamma - 1}{ \gamma + 1}) + \frac{2}{\gamma + 1}##
From here, I think all I need is to find the value of M. However, I don't see how I could do that.
Finally, since ##M= u_{exhaust}/c_s##, All I have to find is ##(\frac{P_1}{P})^{\frac{\gamma -1}{\gamma}}##.
Also, knowing that ##(\frac{P_0}{P_1})^{\frac{\gamma -1}{\gamma}} = \frac{\gamma +1}{2}##
I guess I only need to find ## \frac{P_0}{P}##.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
