Maximum light intensity underwater during seasons?
Maximum light intensity underwater varies with seasons due to the sun's position in the sky, which changes throughout the year, particularly outside the equatorial regions. While considering solar irradiance, it is important to note that winter months generally receive less light and heat, affecting underwater illumination. The discussion highlights the misconception that zenith position remains constant, emphasizing that it significantly influences light penetration. For accurate data on peak average solar irradiation by month, users are encouraged to seek specific resources beyond total solar irradiation datasets. Overall, understanding these factors is crucial for assessing underwater light conditions across different seasons.
Alfreds9
Hi,
I was thinking if maximum light intensity underwater during seasons changes somehow.
I firstly thought about considering monthly solar irradiance (http://neo.sci.gsfc.nasa.gov/view.php?datasetId=CERES_INSOL_M) however I thought this would have been biased at certain latitudes due to seasonal variation of total light hours.
So, not considering algal growth affecting water tubidity and always considering sun being straight above water, do you think that you'd get a stronger (visible, not considering IR or UV) illumination during summer rather than during winter or would they reach 10, 20 or more meters relatively unaffected in either season?
Thank you
Allison
Science news on Phys.org
If the Sun were straight above the water (on the local vertical) the things would be different.
However, unless you live very close to Equator, the Sun will never be in this situation. And the maximum height in the sky varies during the year. I don't see why would you expect to have a constant illumination of the water when we don't get it for the rest of the landscape. In winter everything gets less light and heat from the Sun in the temperate and Nordic regions.
But maybe I misunderstood you question?
Likes Alfreds9
If the sun is straight above water, you don't have summer and winter.
Likes Alfreds9
I see, didn't think about this, thank you very much...I always thought that zenith was zenith and it didn't vary noticeably, with temperature variations being mostly dependant on light hours and longer peak time.
Where can I find peak average solar irradiation by month (meaning the average maximum irradiation of visible light reaching a certain latitude at peak time during a month)?
I can only find total solar irradiation data on NOAA, but since they're a sum of irradiation values and obviously light hours, their total amount is somewhat biased and can't show me when average solar irradiation during peak time is higher during the year.
One could guess that it's higher when its hotter but again I don't know if I can be sure of this since it may just be a variation of infrared irradiation rather than visible light.
Thanks again.
Or even day and night!
Likes Alfreds9
Thread 'Simple math model for a Particle Image Velocimetry system'
Hello togehter, I am new to this forum and hope this post followed all the guidelines here (I tried to summarized my issue as clean as possible, two pictures are attached). I would appreciate every help: I am doing research on a Particle Image Velocimetry (PIV) system. For this I want to set a simple math model for the system. I hope you can help me out. Regarding this I have 2 main Questions. 1. I am trying to find a math model which is describing what is happening in a simple Particle...
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
