Maximum possible percentage error
In summary, the maximum error in the measurement of density can be calculated by adding the percentage errors of mass and length in quadrature, giving a result of 9%. This can also be approximated by adding the percentage errors of mass and length directly, which also gives a result of 9%.
calm_cool
The maximum error in the measurement of the mass and length of the side of a cube are 3% and 2% respectively. What is the maximum error in the measurement of density? (The questions has options as:- (a)3% (b)5% (c)6% (d)9% (e)12%
Density(ρ)= Mass/Volume, Volume(cube)= (Length of cube)^3
I have thought of two ways to do this:-
1) Just by adding the percentage errors, I get the answer as 5%.
2)Or by adding them like this:- 3% + 3*2%=9%
Please tell me which one of them is the correct one. If both are wrong, please tell me how to solve this problem.
I don't think you have the correct approach here.
Think about working with actual numbers.
Say you have a 1M^3 block with a mass of 1000kg
What is it's desnity?
Now what is the worst cast scenario on the errors and figure out what that density would be
You can approach it with either relative or absolute errors, the final result will not matter. However, just adding them is not correct unless the measurements are correlated, which is probably a bad assumption in this case.
Independent errors should be added in quadrature. Note that when you compute the volume of the cube, the error on the side length enters 3 times and these are correlated. This gives an error on the volume of the cube, which a priori is uncorrelated to the measurement and of its mass.
Correlated errors is a required assumption in this case. The problem statement asks for the "maximum error". The maximum error will occur when the errors are correlated in just the right way so that error is maximized.
Given this fact, the applicable rule of thumb is that small percentage errors add when you multiply or divide.
edit: [And multiply when you exponentiate]
Well I'm not sure if what I did is legit or not, I never spent a whole lot of time with statistal things.
I basically brute forced it.
The exact density is ##\frac{M}{V} = \frac{M}{L^3}##
if the margin of error on mass is 3% then the maximum measured value for M is 1.03M, minimum being .97M.
For L it would be 1.02L and .98L
I don't want to give too much away, see if that helps you at all.
While this is true, I do not see how the measurement of weight would correlate with the measurement of a length (unless you already know the density). Of course, this is more related to the formulation of the problem not coinciding with what you would expect in a real situation. In the end, I find that such things lead to misconception and confusion.
Got the answer!
The answer was 9%. When I asked my teacher about this, he did it using the second method that I mentioned as my approach to the solution. Anyways, thanks for the help guys, really like to discuss questions again!
There is an 'engineer's rule of thumb' that when measurements are added (or subtracted), their errors add and when measurements are multiplied (or divided), their percentage errors add so, yes, since density = mass/length^3, the error in calculating the density is (approximately) 3%+ 2%+ 2%+ 2%= 9%.
That is approximate because the "engineer's rule of thumb" is just that- an approximation. To get a more accurate value you could instead do it this way: a fraction is largest when the numerator is largest and the denominator is smallest. Here, the numerator is the mass. Calling the measured mass "M", with error 3%, the largest it could be is 1.03M. Calling the length "L", with error 2%, the smallest it could be is .98L so that the volume could be a little as [itex](.98L)^3= 0.8337L^3[/itex]. The largest the density could be is [itex]\frac{1.03M}{0.8337L^3}= 1.0943(M/L^3)[/itex] which is approximately 9% larger than the calculated density.
(That "engineer's rule of thumb" can be derived using Calculus: if F= x+ y, then dF= dx+ dy. If F= xy then dF= xdy+ ydx. Dividing both sides by F= xy,
[tex]\frac{dF}{F}= \frac{xdy}{xy}+ \frac{ydx}{xy}= \frac{dy}{y}+ \frac{dx}{x}[/tex])
Related to Maximum possible percentage error
What is maximum possible percentage error?
Maximum possible percentage error is a measure of the largest possible error that can occur in a measurement or calculation. It is expressed as a percentage of the true value.
How is maximum possible percentage error calculated?
Maximum possible percentage error is calculated by dividing the smallest possible change in the measured quantity by the true value and multiplying by 100%. This value is also known as the relative error.
Why is maximum possible percentage error important?
Maximum possible percentage error is important because it helps us understand the accuracy and reliability of our measurements and calculations. It allows us to assess the potential impact of errors and make adjustments to improve the accuracy of our results.
How can maximum possible percentage error be minimized?
Maximum possible percentage error can be minimized by using precise and calibrated instruments, reducing sources of uncertainty, and repeating measurements multiple times to account for random errors. It is also important to carefully consider the limitations of the measurement technique being used.
What are some examples of maximum possible percentage error in real-world situations?
Examples of maximum possible percentage error in real-world situations include weather forecasting, medical tests and diagnoses, and financial predictions. In these cases, understanding and minimizing error is crucial for making accurate and reliable predictions and decisions.
