Maximum Static Friction Force for Spinning Disk and Block System
  • Thread starter Thread starter splac6996
    Circle Dynamics
The discussion focuses on calculating the maximum rate of rotation for a spinning disk system involving a penny and a block, considering the static and kinetic friction coefficients. The static friction force is crucial in preventing the penny from sliding off the block as the disk spins. The participants emphasize understanding the maximum static friction force that can act on both the penny and the block. The solution involves applying the relevant equations of motion and friction to determine the critical rotational speed. Ultimately, the goal is to find the maximum revolutions per minute without any sliding occurring between the objects.
splac6996
A penny of mass 3.10g rests on a small 20.0g block supported by a spinning disk. The coefficients of friciton between block and disk are .750(static) and 0.640(kinetic) while those for the penny and block are 0.520(static) and .450(kinetic). What is the maximum rate of rotation in revolutions per minute that the dsk can have, without the block or penny sliding on the disk?
What force prevents the penny from sliding?
static friction
I think I can solve this problem now thanks
Right. So what's the maximum force that static friction can exert on each object?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
