Maximum value of Coefficient of Fibonacci Polynomial
Bling Fizikst
Denote by ##F_0(x), F_1(x), \ldots## the sequence of Fibonacci polynomials, which satisfy the recurrence ##F_0(x)=1, F_1(x)=x,## and $$F_n(x)=xF_{n-1}(x)+F_{n-2}(x)$$ for all ##n\geq 2##. It is given that there exist unique integers ##\lambda_0, \lambda_1, \ldots, \lambda_{1000}## such that$$x^{1000}=\sum_{i=0}^{1000}\lambda_iF_i(x)$$ for all real ##x##. For which integer ##k## is ##|\lambda_k|## maximized?
ok
Tried to find patterns on the coefficients of the polynomials . But could only go as far as : $$x: \frac{i+1}{2}$$ $$x^2: \frac{i(i+2)}{8}$$ for the ##i##th fibonacci polynomial . Quite stuck on this one for a while , so , not sure if i have to change routes . But seems like if i find the coefficients of the polynomial , i can set them all to zero except the one for the ##1000## th power . It seems i can only start thinking about the maximising part after finding the coefficents and setting them to zero .
This becomes complicated quickly. E.g. see the formulas here:
https://arxiv.org/pdf/1505.06697
It says that
F_{n-1}(x)=\dfrac{(x+\sqrt{x^2+4})^n-(x-\sqrt{x^2+4})^n}{2^n\sqrt{x^2+4}}
and
F_{n-1}(x)=\sum_{k=0}^{\lfloor \frac{n-1}{2}\rfloor}\binom{n-k-1}{k}x^{n-2k-1}
which at least gives us a hint how to solve it. And Wikipedia says
The Fibonacci polynomials form a sequence of orthogonal polynomials.
but I haven't figured out what the weight function and the integral domain are.
This is maybe related to a Generating Function.
There is a relation between the Fibonacci polynomials and the standard basis polynomials
$$ x^n=F_n(x)+\sum_{j=0}^{\left\lfloor \frac{n-1}{2} \right\rfloor}(-1)^{j+1}(\binom{n}{j+1}-\binom{n}{j})F_{n-2j-2}(x) $$ where ## n\gt0 ## and ## F_{-1}(x)=0 ##.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
