MHB Maximum Value of k in $(1+\frac{1}{a})(1+\frac{1}{b}) \ge k$ is 9
  • Thread starter Thread starter Mathick
    Maximum Value
For positive real numbers a and b such that a + b = 1, the inequality (1 + 1/a)(1 + 1/b) is established, leading to the conclusion that the maximum value of k is 9. This is derived using Cauchy's inequality, which shows that 1 + 2/ab achieves its maximum when ab is minimized, specifically at ab = 1/4. Substituting a = b = 1/2 confirms that the equality holds, resulting in k = 9. The calculations demonstrate that the maximum value of k is indeed 9, validating the initial assertion. Thus, the maximum value of k in the given inequality is confirmed as 9.
Mathick
For any positive real numbers a, b such that $a+b=1$, the inequality $(1+\frac{1}{a})(1+\frac{1}{b})\ge k$. Find the maximum value of $k \in \Bbb{R}$.
I did:
$(1+\frac{1}{a})(1+\frac{1}{b})= \frac{a+1}{a} \cdot \frac{b+1}{b}=\frac{ab+a+b+1}{ab}= 1+\frac{2}{ab} \ge k$
Using the Cauchy's inequality, we have
$\frac{a+b}{2} \ge \sqrt{ab} \implies \frac{1}{4} \ge ab \implies \frac{1}{ab} \ge 4 \implies \frac{2}{ab} \ge 8$
Thus,
$(1+\frac{1}{a})(1+\frac{1}{b})= 1+\frac{2}{ab} \ge 1+ 8 = 9$
Therefore maximum value of k is 9. Is it correct?
Mathematics news on Phys.org
Hi Mathick,
The answer is correct, but you should give values of $a$ and $b$ that make the equality hold. Letting $a = b = 1/2$ will do.
And I did:
Substitute b = 1-a and you'll get
$$k(a)\leq \frac{(a+1)(a-2)}{a(a-1)}$$
Calculate the extremum by using the 1st derivation:
$$\frac{dk}{da}\leq \frac{2(2a-1)}{a^2(a^2-1)}$$
which is zero if $$a = \frac12$$. Determine b.
earboth said:
And I did:
Well... but how to find a value of k now?
Good morning,
replace a by $$\frac12$$ in
and you'll get
$$k\left(\frac12 \right) \leq \frac{\left(\frac12 +1 \right)\left(\frac12 - 2 \right)}{\frac12 \left(\frac12 - 1 \right)} = \frac{-\frac94}{-\frac14}=9$$
That is the maximum value for k.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
