Maximum velocity of object dropped from cliff
  • Thread starter Thread starter Jigen
    Maximum Velocity
The maximum velocity of an object dropped from a 20 m cliff, assuming no air friction and gravity of 10 m/s², is 20 m/s. Initial calculations suggested 15 m/s, but this was incorrect due to misunderstanding the average speed during free fall. The object accelerates, reaching 10 m/s after 1 second and 20 m/s after 2 seconds. Using the SUVAT equation V² = U² + 2aS confirms that the final velocity is indeed 20 m/s. Therefore, the correct answer is 20 m/s.
Jigen
Just finished an exam. One problem is bothering me and I want to be certain if it's right.
What is the maximum velocity of an object dropped from a 20 m cliff?
Assume no air friction and gravity is 10 m/s/s.
None given, but I assume v=gt is relevant.
15 m/s.
My reasoning was that if after 1s, the object fell 10m at 10m/s,
and after 2s, the object has fallen 30m (10m + 20m) at 20m/s (10m/s + 10m/s),
then I can divide the 2nd speed increment in half to determine speed at 20m fall (10m/s + 5m/s).
I tried using equations before answering 15.
v=gt by itself can't work without t (t was not given).
d=1/2gt^2 tells me the object fell for 2s, but that doesn't seem right (it would have traveled 30m).
Assuming t=2s is right, v = 10m/s/s * 2s = 20m/s.
So which is right: 15 or 20?
15 m/s.
It's 20.
In the first second it reaches 10m/s, but travels only 5m [average speed = (0+10)/2 = 5
In the second second second is increases to 20 m/s, traveling a further 15m [average speed = (10+20)/2 = 15.
Oh, that's right... it has to be averaged since speed isn't constant. Thanks.
In my day we would remember one of the the SUVAT Equations
http://en.wikipedia.org/wiki/Equations_of_motion
probably V2 = U2 + 2aS
where
V = final velocity
U = initial velocity
a = g ≈10
s = displacement
Reduces to
V2 = 2as
= 2 * 10 * 20
= 400
so V=20
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
