Maxwell's Equations: are they complete?
Maxwell's Equations consist of a set of equations that describe electromagnetic fields, but they are not complete as they leave one equation short when considering the scalar equations and unknowns involved. The continuity equation is derived from Maxwell's equations, indicating they are interdependent and complicating the specification of initial states for the system. A potential formulation using a scalar potential V and a vector potential A clarifies the degrees of freedom in the equations. This formulation introduces gauge freedom, allowing for different choices of V and A while still describing the same physical situation. Proper initial and boundary conditions, such as particle positions and velocities, are essential for solving the equations in practical scenarios.
chingkui
\nabla \cdot D= \rho
\nabla \cdot B=0
\nabla \times E=- \partial B/ \partial t
\nabla \times H=J+ \partial D/ \partial t
Together with the continuity eq:
\nabla \cdot J=- \partial \rho / \partial t
There are 9 scalar equations and 16 scalar unknowns (B, E, D, H, J, \rho)
If we are supplied with the relations that relate B to H and E to D (e.g. a linear media relation):
D=f(E)
H=g(B)
we have 6 more scalar equations and therefore 15 equations in total. We are still one equation short of solving the Maxwell Eq, if we are supplied with appropriate B.C. and Initial Conditions, and we do not constrain the current density J and charge density \rho. In that case, how do we solve the Maxwell Equations?
Likes Delta2
If you describe the EM field by its potentials V and \vec{A}
and the source field by the charge \rho and current \vec{J}
Then you need just eight equations:
\nabla \cdot B=0
\nabla \times E=- \partial B/ \partial t \ \ \ \ (=3x)
\nabla \times H=J+ \partial D/ \partial t \ \ \ \ (=3x)Regards, Hans
The continuity equation is not an independent assumption, but follows from Maxwell's equations (apply the curl to the fourth). However, they form an interdependent set of equations, so it's not at all obvious from these equations what the degrees of freedom are, or how to specify the initial state of the system (the field and the particles).
To see the degrees of freedom more clearly, you should use a potential formulation. A statement of a potential function V and a vector potential \vec A will then be necessary and sufficient to give the field everywhere (you also need the positions and velocities of all the particles for the system ofcourse). The choice on V and \vec A is not unique though. There's some freedom of choice which we call gauge freedom.
For the Coulomb gauge, the initial condition you should specify are the positions and velocities of all particles, the field \vec A and its time derivative (since it obeys a wave equation).
There are boundary conditions that apply too, for example solving for a field within a waveguide.
Claude.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
