MHB Mean & Std Dev for Norm Dist. Exam Marks - 450 Stud.
To find the mean and standard deviation of exam marks for 450 students with a normal distribution, the number of first-class students (25) and failed students (90) are key data points. The first-class threshold is set at 60% or more, while the failure threshold is below 30%. This distribution indicates that 335 students scored between 30% and 60%. Calculating the mean and standard deviation requires additional statistical methods or formulas based on these figures. Providing initial calculations or attempts would facilitate more targeted assistance.
wajeehayas
Assuming that the number of marks scored by a candidate is normally distributed, find the mean and the standard deviation, if the number of first class students(60% or more marks) is 25, the number of failed students(less than 30%marks) is 90 and the total number of candidates appearing for the examination is 450.
Help
Mathematics news on Phys.org
Hello wajeehayas and welcome to MHB! :D
We ask that our users show their progress (work thus far or thoughts on how to begin) when posting questions. This way our helpers can see where you are stuck or may be going astray and will be able to post the best help possible without potentially making a suggestion which you have already tried, which would waste your time and that of the helper.
Can you post what you have done so far?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
