I Meaning of average pressure in statistical mechanics
The discussion explores the derivation of pressure in statistical mechanics as presented by Kittel and Kroemer, emphasizing the relationship between energy and volume under isentropic conditions. It clarifies that average energy is calculated using probabilities associated with different energy states, rather than simply averaging all possible energies. The distinction is made between classical and quantum states, highlighting that in statistical physics, states are defined by probabilities rather than precise positions or momenta. This understanding is crucial for interpreting average pressure, which is similarly dependent on the system's state. The conversation ultimately underscores the complexities of defining physical quantities in the context of quantum mechanics and statistical ensembles.
LightPhoton
TL;DR Summary
he fact that we are defining it in terms of such precise and singular conditions (isentropic compression of one particular state at a time) makes me have trouble understanding its physical meaning specifically, on how the actual pressure measured is related to average pressure, given the specific condition to measure ##p_s##.
Kittel and Kroemer derive the pressure of a statistical state in the following way:
They assume a volume compression of a system such that the quantum state of the system is maintained at all times; thus, the entropy ##(\sigma)## is constant in the process of compression. Now let the energy of the system with state ##s## be ##\epsilon_s##, then
$$\epsilon_s(V-\Delta V)=\epsilon_s(V)-\frac{d\epsilon_s}{dV}\Delta V+...$$
Since the work done on the system is equal to the change in energy of the system,
$$U(V-\Delta V)-U(V)=\Delta U= -\frac{d\epsilon_s}{dV}\Delta V$$
In terms of pressure, ##p_s## on the state we can write ##\Delta U = p_s\Delta V##, thus getting
$$p_s=-\frac{d\epsilon_s}{dV}$$
Defining ##p=\langle p_s\rangle ##
$$p=-\bigg(\frac{\partial E}{\partial V }\bigg)_{\displaystyle\sigma}$$
where ##E## is the average energy of the system.
Now, it makes sense to me to talk about average energy, since it's just the sum of all possible energies divided by the number of them. The same would have been the case with pressure, but the fact that we are defining it in terms of such precise and singular conditions (isentropic compression of one particular state at a time) makes me have trouble understanding its physical meaning specifically, on how the actual pressure measured is related to ##p## given the specific condition to measure ##p_s##.
No it's not. The average energy is the sum of all energies multiplied by probabilities of those energies. Those probabilities are defined by the state of the system. In the quantum canonical ensemble this state is the mixed quantum state describing a thermal equilibrium at temperature ##T##. In this sense, average energy and average pressure involve the same kind of average, which depends on the state.
Perhaps your confusion stems from thinking of a state as a classical state in which all positions and momenta are well defined. But here, in the context of statistical physics, the state is not like that. The state only determines probabilities of positions and momenta. In the quantum case, the state cannot even be defined by a single wave function. The thermal state is a mixed quantum state, in which even the wave function is uncertain.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
