Meaning of having powerful signal near to 0Hz
A powerful signal near 0 Hz indicates a strong DC component, which could be due to a voltage offset or gravitational acceleration, depending on the signal's coupling and circuit adjustments. In data analysis, it's common to remove DC components to focus on oscillatory signals, often by subtracting the mean or fitting a polynomial. The highest frequency in a Fourier transform is limited to half the sampling frequency, necessitating a sampling rate of at least 200 Hz to capture frequencies up to 100 Hz. For reducing signals in the 25-100 Hz range, applying wavelet transforms and reconstructing the signal can be effective. Evaluating the power spectral density can help assess the efficiency of the signal processing approach.
ramesses
Hello
I computed, with python scipy.rfft, the Fourier transform of signal coming from an accelerometer.
I don't understood what this is the meaning of having a powerful signal near to 0 Hz ?
It means that there is a strong DC (or near DC) component to the signal. It may just be a voltage offset, or it may be the acceleration of gravity. It depends on how the signal is coupled and how the circuit is adjusted.
When we analyze many different data sets for the oscillatory components (temperature, tides, sounds) we often take a pre-analysis step to remove the DC or near DC components. Sometimes, it is just subtracting the mean of the whole signal. Other times it may be fitting to a cubic polynomial and then subtracting the cubic polynomial from the original signal and then taking the Fourier transform of the oscillatory components.
In any case, graphs are easier to understand if care is taken to preserve the proper units on both the horizontal and vertical axes (frequency in Hz and acceleration in m/s/s, for example).
Likes berkeman and donpacino
thank you :)
My last question is about band. My sensor frequency is about 100 Hz
Why do I have to use 0~50 Hz in fft ? Why not to use 0~100 Hz ?
ramesses said:
thank you :)
The highest frequency in an fft is 1/2 the sampling frequency.
If your sensor is sensitive to 100 Hz, you can increase your sampling rate to 200-1000 Hz and see higher frequencies.
I have a sampling of 30 minutes with my sensor with 100 Hz. and I want to reduce eliminate signal in [25~100] Hz.
So what I do is :
I apply for each 100 samples a wavelet of second level.
I put 0 in details, and reconstruct the signal.
Now to see the efficiency, what do I need ?
Is the power spectral density useful in my case ?
I have Mass A being pulled vertically. I have Mass B on an incline that is pulling Mass A. There is a 2:1 pulley between them. The math I'm using is: FA = MA / 2 = ? t-force MB * SIN(of the incline degree) = ? If MB is greater then FA, it pulls FA up as MB moves down the incline. BUT... If I reverse the 2:1 pulley. Then the math changes to... FA = MA * 2 = ? t-force MB * SIN(of the incline degree) = ? If FA is greater then MB, it pulls MB up the incline as FA moves down. It's confusing...
Hi. I noticed that all electronic devices in my household that also tell time eventually lag behind, except the ones that get synchronized by radio signal or internet. Most of them are battery-powered, except my alarm clock (which runs slow as well). Why does none of them run too fast? Deliberate design (why)? Wrong temperature for quartz crystal? Decreasing battery voltage? Or just a coincidence?
