valenumr
- 469
- 193
Fluid mechanics is a bit beyond what Newton had in mind.weirdoguy said:What @ergospherical discussed is also Newtonian mechanics, just a bit advanced![]()
I don't see why the latter form doesn't make sense. For example, you could have two separate forces being applied to an object of mass m -- ##F_1## and ##F_2##. We could have ##F = F_1 + F_2 = ma_1 + ma_2 = m(a_1 + a_2)##.meekerdb said:But I think they missed a point that acceleration is not only dimensionally different, it's also a vector, and so is F. So F=(m1+m2)a makes sense but F=m(a1+a2) doesn't.
Can you help me with why it doesn't when it appears to me to be fine? Or is there an 'always' that needs to be added somewhere.meekerdb said:F=m(a1+a2) doesn't.
It is not generally correct that multiplication is simply a higher form of addition. When you were in elementary school this is indeed how the topic is introduced, but that is simply because elementary school students only know addition and are not mentally prepared for an axiomatic approach to math. In the axiomatic approach, multiplication is not constructed from addition, but a set is proposed and multiplication is defined abstractly as an operation on elements of that set with certain axiomatically imposed properties. It is those axioms that define multiplication, not the elementary-school construction.mremadahmed said:Multiplication is higher form of addition.Division is higher form of subtraction.
What does F=ma means. m is in kg. a in ms-2.How can both multiply.They cannot add or subtract.
Why any quantities can multiply or divide,contrary to adding and subtracting.
Yes, and so what? One of the axioms of any vector space has to do with the multiplication of a vector by a scalar.meekerdb said:First thing to notice is that force and acceleration are vectors, mass is a scalar. So the multiplication is in vector space.
The vector space axioms don't even define the multiplication of two vectors. The only operations defined in the vector space axioms are addition of vectors and multiplication by a scalar.meekerdb said:Multiplying a vector by a scalar is quite different from multiplying two vectors which may be a dot product or a cross product.
This has nothing to do with your earlier statement in post #53 that ##F = m(a_1 + a_2)## doesn't make sense. I gave you a scenario in which it does make sense.meekerdb said:But you can't add things with different units and sometimes you can't add things with the same units, e.g. torque+energy.
Torque and energy have different units. And if you meant force and torque, they have different units, as well.meekerdb said:But you can't add things with different units and sometimes you can't add things with the same units, e.g. torque+energy.
They doMark44 said:torque and energy don't have the same units
They have the same dimensionality. Not the same units.ergospherical said:They do
Having equal dimensionality implies they can be expressed in the same units…jbriggs444 said:They have the same dimensionality. Not the same units.
I distinguish between units and dimensions.ergospherical said:Having equal dimensionality implies they can be expressed in the same units…
Indeed, because they are different things… (loosely, dimensionality is associated with an [infinite] set of possible units…)jbriggs444 said:I distinguish between units and dimensions.
With radians (arguably a dimensionless unit) as a conversion factor between torque applied and energy expended through a unit rotation angle).ergospherical said:Indeed, because they are different things… (loosely, dimensionality is associated with an [infinite] set of possible units…)
Nonetheless torque and energy share the same set of units
dW = F . dr
t = r x F
The ideal model of the discussed experiment assumes that the first falling snowflakes (constant vertical precipitation velocity, constant density) touch the ground at the moment of starting the measurement of the dozer movement (horizontal, uniform rectilinear motion).AlexS said:Interesting conversation, I think that the criterion with unit is very important.I actually think that after you have this fundamental defining formulas such as average speed=total distance/total time, you can obtain other formulas such as Galileo's formula(v square=v0 square+2ad) just doing the math,without any trouble. But,in my view, the problem is still with this fundamental equations. For instance, why the speed is distance per time and not distance multiplied with time? I see the proportionality between time and distance (if speed is constant), but I still cannot perfectly understand this problem.
Different animals entirely; I agreejbriggs444 said:I distinguish between units and dimensions.
Feet go up to twelve. That's two more.sophiecentaur said:Different animals entirely; I agree
'They' had to invent dimensional analysis to take care of this and other problems. As far as I know, the US has to accept the same convention for dimensions as we use in UK, despite their continuing love affair with feet.
I wonder where that movie would be now without the volume control gag.jbriggs444 said:Feet go up to twelve. That's two more.
With apologies to Spinal Tap.
Let's take a simple equation from rectilinear motion: ##\Delta x=vt##. In other words, displacement equals the product of the velocity and the time. You know that multiplication is a series of additions. So if you have a velocity of ##2 \ \mathrm{m/s}## for 3 seconds you travel 2 meters in the first second, 2 meters in the next second, and finally 2 meters in the third second. ##2 \ \mathrm{m}##+##2 \ \mathrm{m}##+##2 \ \mathrm{m}##=##6 \ \mathrm{m}##.mremadahmed said:Why any quantities can multiply or divide,contrary to adding and subtracting.
There are onlysophiecentaur said:A question that gets my mind going in ever decreasing circles is "what is it about three that allow it to be applied to so many quantities?" . There's a 'threeness' that is outside the physical world. We do our three times table but when we explain it to a child we talk about three apples and four boxes of three apples etc.
I haven't the reference material on hand, but isn't it "One, Two, Many, Lots" ?jbriggs444 said:There are onlyfourmany numbers. One, two, three and many.
