I Meaning of the notations: ##\mathbb{Z}[\frac{1}{a}]##
elias001
The following is taken from Abstract Algebra: A First Course by Stephen Lovett
Background
Exercise Let ##D=\{2^a 3^b\mid a,b,\mathbb{N}\}## as a subset of ##\mathbb{Z}##. Prove that ##D^{-1}\mathbb{Z}## is isomorphic to ##\mathbb{Z}[\frac{1}{6}]## even though ##D\neq\{1,6,6^2,\ldots\}##
Question:
I would like to know how is the notation: ##\mathbb{Z}[\frac{1}{6}]## or ##\mathbb{Z}[\frac{1}{a}]## defined? Also I have seen ##\mathbb{Z}[\frac{1}{2},\frac{1}{3}]##, and I would like to know how that is also defined.
Thank you in advance.
\mathbb{Z}\left[\frac{1}{6}\right] are all polynomials in 1/6 with integer coefficients. It is what you get if you substitute x=1/6 in polynomials from \mathbb{Z}[x].
The same for \mathbb{Z}\left[\frac{1}{a}\, , \,\frac{1}{3}\right]. Take \mathbb{Z}[x,y] and replace x=1/a and y=1/3.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
