Measure angular velocity and acceleration from missing tooth wheel
To develop a mathematical model for a digital ignition system, measuring angular velocity and acceleration is essential. Using a 36-1 tooth wheel, one can determine angular velocity by measuring the periods of consecutive teeth. Subtracting the periods of the same tooth at different times provides the necessary data to calculate angular acceleration. For improved accuracy, collecting multiple period measurements allows for plotting angular velocities against time, revealing the nature of angular acceleration. This method ensures a reliable assessment of the system's dynamics.
nick26
Hi,
I need to come up with a math model for a digital ignition system. I've been thinking about it and I think that I need to measure 2 things to be able to calculate when I have to start charging the coil. They are the angular velocity and the acceleration but how can I do it? the idea is to use a 36-1 wheel and then measure each tooth periods. If I subtract the period of two teeth will that give me the acceleration?
Thanks!
Subtracting the period of two teeth will give the difference of the periods of these two teeth.
You will need at least two tooth periods, that is measure the period of the same tooth two consecutive times. The average angular speeds for the two periods are ##\bar \omega_1=\dfrac{2\pi}{T_1}## and ##\bar \omega_2=\dfrac{2\pi}{T_2}##.
Assuming constant angular acceleration (you need to convince yourself that this is the case in your system - see below how), the instantaneous angular speed is equal to the average at the half-time mark. In other words,
##\omega_1=\dfrac{2\pi}{T_1}## at ##t_1=\dfrac{T_1}{2}##
and
##\omega_2=\dfrac{2\pi}{T_2}## at ##t_2=T_1+\dfrac{T_2}{2}##.
Then the angular acceleration will be given by ##\alpha=\dfrac{\omega_2-\omega_1}{t_2-t_1}.##
If you can collect many successive periods, say 10 or so, then you will improve your accuracy because you will be able to plot the ##\omega_i## points vs. the ##t_i## points. You should get a straight line with a slope equal to the angular acceleration. If the line is not straight, then the angular acceleration is not constant.
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
I know that mass does not affect the acceleration in a simple pendulum undergoing SHM, but how does the mass on the spring that makes up the elastic pendulum affect its acceleration? Certainly, there must be a change due to the displacement from equilibrium caused by each differing mass? I am talking about finding the acceleration at a specific time on each trial with different masses and comparing them. How would they compare and why?
