I Measurement for uncertainty in nonlinear model
The discussion focuses on finding a method to measure uncertainty in a nonlinear model, particularly regarding uncertainties in sampled data and the curve fitting process. The user seeks accessible information on uncertainty propagation and regression error handling, recalling past experiences with similar calculations. They describe a specific output derived from four detector signals and express a desire to implement calculations in code, including the use of Jacobian and Covariance matrices for variance and confidence interval calculations. Clarifications are requested regarding the nature of the detector signals and the correlation of their uncertainties. The conversation emphasizes the importance of understanding the mathematical relationships involved in uncertainty measurement.
liquidFuzz
I would like to find a measurement for uncertainty in a calculation I have. So, the uncertainties I have, or at least as far as I understand.
  1. uncertainty of sampled data that is used to optimized parameters of the model.
  2. uncertainty in the curve fit procedure
Is there some fairly accessible (I mean cognitive) information about how I should approach this? I remember doing this kind of calculations back when I was studying, but it was a loooong time ago. If anyone could point me in the right direction..?
Thanks in advance!
Hm. i might have been vague in my post, sry... We could use the growth model example, but I fear it might be to complicated, for me... I have four detector signals Sxx where my output = (Saa - Sab)(Sba - Sbb). The detector is the same so all signals have the same uncertainty. If understand this I should be able to use the Example formulae table, line 3 and 7, in the first link you to get an expression for the variation/standard deviation of my out signal.
I think i understand the subject well enough to implement it in code (which I usually do when I thinker). One question though. To calculate the variance of the function value I take the Jacobian J of the function and the Covariance matrix C of the curve fit and multiply as such v = J C J T. Which I then use to calculate my confidence intervals, ci = Z sqrt(v). Is this correct..? And if someone would take a stab at explaining the vector matrix multiplication... 🤔
Treading carefully is wise... :wink:
If not the growth model, then what model are you using (*) ?
(The guys here use
Marquardt, D.W. 1963. An algorithm for least squares estimation of nonlinear parameters. Journal of the Society of Industrial Applied Mathematics 2:431–441.​
to determine coefficients in a model, but their data (in table 2) are only in the second part of the curve; very unsatisfactory... )
What are ##S_{aa}## etc ? Voltmeter readings, Scintillator counts, ... ? Are you sure their uncertainties are completely uncorrelated ?
Line 3 being ##f = A - B \Rightarrow \sigma_f^2 = \sigma_A^2 + \sigma_B^2 + \sigma_{AB}^2 ## ?
Line 7 being ##f = \frac A B## makes me wonder if you mean output = (Saa - Sab)/(Sba - Sbb) instead of (Saa - Sab)(Sba - Sbb) ?
(*) is 'output' a simple number or a formula with several coefficients you try to find ?
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
