Measuring Acceleration of Falling Object: Mark Symbol?
The discussion revolves around measuring the acceleration of a falling object using ticker tape and the appropriate symbols for the marks on the tape. The user describes conducting an experiment with a car and a mass, but seeks clarification on how to denote the marks made on the tape. There is confusion about whether the marks are pre-printed or created during the experiment, which affects the analysis. It is suggested that in a lab notebook, measurements should be recorded as "number of marks," with conversions to time or distance necessary for data analysis. The importance of understanding the measuring device's calibration is emphasized for accurate reporting.
gnome222
I used a ticker to measure to measure the acceleration of falling object. And and now I am writing report about it and the problem is what symbol is used for the marks on the ticker tape? Like for grams (g). What would you use for marks(?) ?
It's not clear how you can measure the acceleration of an object just by making some marks on a ticker tape. What are the marks used to indicate?
Please describe more fully what you did.
well, i got a car with constant velocity and let it run for three seconds with ticker tape attached to it. Then i got a 1 gram mass and throw it from 2 meters , 1.75m, 1.5m,1.25m,1 m with ticker tape attached to it. Then i took the frequency of the constant velocity car and found the acceleration of the mass. But my question is what symbol would you use for the marks on the ticker tape when you are processing the data.
You haven't explained how the marks got on the tape. Were they on the tape when it was supplied? Did you have a machine put the marks on the tape as the car pulled it through the machine? If so did it put them on at regular time or regular distance intervals? It makes a difference to what symbol might be appropriate.
dont u think that there wouldn't be any need of using velocity, displacement and time and then calculate acceleration if there was any possible means of calculating acceleration just like that... please read the basic things about a physical quantity..."
In a lab notebook, it is appropriate to record measurements in terms of "number of marks". It is always proper to record measurements in original form. When analyzing the data it is usually important to be able to convert from "number of marks" to elapsed time or some such. The conversion from raw reading to a numeric measure (and error bar) reported in standard units will depend on details of the measuring device and its calibration. We have not been given those details.
Assume that this is a case where by sheer coincidence, two sources of coherent single-frequency EM wave pulses with equal duration are both fired in opposing directions, with both carrying the same frequency and amplitude and orientation. These two waves meet head-on while moving in opposing directions, and their phases are precisely offset by 180 degrees so that each trough of one wave meets with the crest of the other. This should be true for both the electric and magnetic components of...
