Measuring distance, speed and clock
In summary, an expert summarizer of content would say that an individual can measure their speed by using the Doppler effect, measure distance by using clocks, and measure other times by using the speed and the Lorentz formula. However, given proper time, an individual can also measure distance to an object at rest relative to them, as well as the time dilation caused by relative motion.
  • #36
Stephanus said:
I know, it's been a week since this post. But I'd like to ask anyway. I'm new in SR, so there are many symbols which I don't recognize. What is the meaning of these symbols?
What does ##t_r\text{ time of the reception}## mean?
Which one is correct?
A: tr = January 1st 2015, 18:00; te = January 20th 2015, 19:30, or something like
B: tr = 20 seconds, te = 30 seconds
It's likely B, but if it's B then, what is t? The reverse of frequency? Needs confirmation here.
Thanks a lot.
Time of reception is the instant that the signal is received (detected), and t in discussions usually means clock time, such as 18:00:00.
The time of reception is always later than the time of emission; the difference is the time for the signal to travel. First a signal is emitted by for example a flashlight at te = January 20th 2015, 19:30:00, and next that signal is received by for example your eyes at tr = January 20th 2015, 19:30:01.
But in the comment that you refer to, the starting time is set at 00 seconds and the counting is in seconds.
  • #37
Thanks a lot.
If I'm understanding the question correctly, B is correct. A is an expression of coordinate time, while B appears to be expression of proper time.
See wiki https://en.wikipedia.org/wiki/Proper_time
In relativity, proper time along a timelike world line is defined as the time as measured by a clock following that line.
So proper time is a time interval. It can be measured with a single clock, between any two events. In the post you took this snippet from, I specify that one uses the meeting point of A and B as one of the events, then you can give times after the meeting a proper time interval of "ten seconds after the meeting" or "10 seconds before the meeting". You also have to specify which clock you are referring to, i.e. A's watch reading or B's watch reading.
And a brief look at wiki's article on coordinate time, such as the ever-popular UTC, might also be helpful as a contrast, though you don't need to study all the details. Kknowing enough to distinguish a coordinate time from proper time would be very helpful though. https://en.wikipedia.org/wiki/Coordinated_Universal_Time
  • #38
Thanks, I just tried to ask another question when your correction arrive. I suspect it's B. But I need to confirmation.
##\beta## and ##\gamma## I already know. But ##tr## and ##te## is new for me.
  • #39
Thanks Harrylin for the answer. Now I can read pervect answer unobstacled.
pervect said:
I would recommend the method used by Bondi in "Relativity and common sense". I believe I've seen it online, but I'll let you google for it. to avoid possible issues with the links being less than legitimate...
  • #40
You should be! That was your answer after all. :smile:
Coordinate time and proper time. Thanks a lot. That makes many things clear for me.
  • #41
pervect said:
Basically, if you have two observers, one of which is moving relative to the other, who synchronize their clocks such that they both read zero when they are colocated, you can write a very simple relationship between the proper time of emission for one observer, and the proper time of reception for the other:
##t_{r} = k t_{e}##
where ##t_r## is the time of reception, and ##t_e## is time time of transmission. If you insist on synchronizing your clocks differently , then you'd need to rewrite this equation as
##(t_r - c_r) = k \, (t_e - c_e)## and set the values of ##c_r## and ##c_e## such that the receiving clock reads ##c_r## when the transmitting clock reads ##c_e## at the moment when the two clocks are colocated.
Dear pervect, dear PF forum. I'd like to ask a question here.
..when the transmitting clock reads ##c_e## at the moment when [..]
I think ##c_e## is coordinate time, then.
So
A: Are ##c_e## and ##c_r## coordinate times?
B: Is ##k## a contant?
C: If ##k## is a contant and ##t_e## is proper time, then ##kt_e## is proper time. Is this true?
Supposed p is proper time and c is a coordinate times. Just like in vectors
Can I ask simple question?
p+p ->p
p-p -> p
c+p -> c
c-p -> c
c-c -> p
is this true?I don't think there's p-c.
what is ##\text{proper time } - \text{ coordinate time}##?
What is the result of ##{t_r - c_r}##
D: proper time?
E: coordinate time?
Thanks
  • #42
So
p+p ->p
p-p -> p
c+p -> c
c-p -> c
c-c -> p
D: proper time?
E: coordinate time?
Thanks
Proper time is the Lorentz length of the worldline ##\sqrt{\Delta t^2-\Delta x^2}##. If the worldline is brought to rest ( becomes vertical, v=0) the proper time = t (coordinate time).
See https://en.wikipedia.org/wiki/Proper_time
  • #43
So
Thinking it over, yes, ##t_e - c_e## is a proper time, because it's an interval, making both ##t_e## and ##c_e## coordinate times, because neither ##t_e## or ##c_e## in isolation is an interval. However, the expression ##t_e - c_e## , intended to be "simple" and intuitive, as written is actually not a coordinate independent expression for the underlying concept of proper time ##\tau_e##. The concept of the proper time interval, ##\tau_e## is a coordinate independent concept, which is the same for all observers. The expression I which I wrote down, ##t_e - c_e## is a coordinate dependent expression that is equal to the proper time interval ##\tau_e## only in a particular coordinate system, the coordinate system associated with the emitter.
I'd call k a parameter, which depends on the relative velocity between the transmitter and receiver. If the relative velocity is constant, which is the case I was addressing, then k is constant.
##t_e - c_e## is a proper time, so that ##k \, (t_e - c_e)## is a proper time. Similarly ##t_r - c_r## is a proper time. The ##\tau_e = k \tau_r## is the true coordinate independent relationship between proper intervals. My use of ##t_e## and ##c_e## was an afterthought, intended to show you one simple way to calculate the proper time in the relevant coordinate system, the one associated with the emitter. But it only works properly in that particular coordinate system, it's not a general definition of the concept of proper time.
In general it doesn't make sense to add proper time to coordinate time, though of course the difference between coordinate times is equal to the proper time if you choose the right coordinate system. But it doesn't work for arbitrary coordinates.
  • #44
pervect said:
Basically, if you have two observers, [..]you can write a very simple relationship between the proper time of emission for one observer, and the proper time of reception for the other:
##t_{r} = k t_{e}##
Did you mean
"Basically, if you have two observers, you can write a very simple relationship between the proper time of emission for one observer, and the proper time of reception for the other:"
A: ##\tau_{e} = k \tau_{r}##, or
B: ##\tau_{r} = k \tau_{e}##, or
C: ##t_{r} = k t_{e}##
Sorry, I'm new here. So any mistake will lead me lost very far away. I think "B". Because if t is coordinate time, then I don't think "coordinate time" can be multiplied. It can be added, substracted, but not multiplied.
Thanks for any respond.
  • #45
Did you mean
##\tau_e## and ##\tau_r## are both proper times, not coordinate times. I'm not sure why you think otherwise. However, if we assign the coordinate value of 0 to the point where the emitter and receiver are co-located, so that the time coordinate where the meet is given the value of zero, and if we also assign the time coordinate ##t_e## by the reading of the emitter clock (and assign the coordinate ##t_r## similarly to the reading on the receiver clock), we can also write ##\tau_e = t_e## and ##\tau_r = t_r## , i.e. the proper times are equal to the coordinate times when we choose our coordinate system and origin correctly. So the distinction isn't too critical if we make the right coordinate choices, but if we want to deal with general coordinates we have to be more careful.
The expression ##\tau_e = k \tau_r## and ##\tau_r = k \tau_e## are both true. Note furthermore that the value of "k" depends only on the relative velocity between emitter and receiver, and neither "k" nor "v" changes in anyway if you switch the labels on the transmitter and receiver.
Try rerading Bondi's book "Relativity and Common Sense" if you can get a hold of it, he takes basically the same approach.
  • #46
pervect said:
##\tau_e## and ##\tau_r## are both proper times, not coordinate times. I'm not sure why you think otherwise. [..]
Thanks pervect, for your reply. Because you said in the previous post ##t_{r} = kt_{e}##, but later you wrote ##\tau_{r} = k\tau_{e}##. But thanks for your responds. Actually download Bondi ebook. I've read it at a glance. But, I've been reading your post, and I want to at least fully understand Post #17, before I go further.
  • #47
Stephanus said:
Thanks pervect, for your reply. Because you said in the previous post ##t_{r} = kt_{e}##, but later you wrote ##\tau_{r} = k\tau_{e}##. [..]
Stephanus, perhaps you overlooked or did not understand pervects answer that he gave already (slightly rearranged):
" when we choose our coordinate system and origin correctly, we can also write ##\tau_e = t_e## and ##\tau_r = t_r## , i.e. the proper times are equal to the coordinate times."
And that's, I think, just what he did in his first post on that sub topic. :wink:
  • #48
How can that be right? For sure those two k's cannot be the same! Those times are not "relative", they correspond to events. Thus I would think that if ##\tau_e = k \tau_r## then ##\tau_r = \tau_e/k##
Likes Stephanus
  • #49
harrylin said:
Stephanus, you overlooked or did not understand pervects answer that he gave already (slightly rearranged):
Thanks harrylin for your responds. But, first pervect said
pervect said:
Thinking it over, yes, ##t_{e}−c_{e}## is a proper time, because it's an interval, making both ##t_{e}## and ##c_{e}## coordinate times
I think by that he also mean ##t_{r}-t_{r}## is a proper time and ##t_{r}## and ##c_{r}## are coordinate times. How can we even multiply coordinate time? ##kt##, and then he corrected it's not ##kt_{e}##, but it's ##k\tau_{e}##. Because he once made mistake, so I want confirmation because I'm afraid he made another mistake :smile:.
  • #50
I was on the phone between your posts. I think if k>1 then ##\tau_r = k \tau_e##, for a convenient way, we can choose ##k\tau_r = \tau_e## if k<1.
Supposed you ##\tau_r = 14## and ##\tau_e=10##. We could write ##\tau_r=1.4\tau_e##.
But if ##\tau_r = 10## and ##\tau_e = 7##, we could write ##0.7\tau_r = \tau_e##. But, I just let that pass, I want to learn the next paragraph in #17, perhaps I could glean some answer, before I ask pervect/this forum again.
  • #51
What?? Post 50? And I am still grabbing Post 17?? I'm afraid the administrator will close this thread. Hmmh...
  • #52
Stephanus said:
Thanks harrylin for your responds. But [..] How can we even multiply coordinate time? ##kt##, and then he corrected it's not ##kt_{e}##, but it's ##k\tau_{e}##. Because he once made mistake, so I want confirmation because I'm afraid he made another mistake :smile:.
That was not a correction, as he explained (and I repeated it); and in the Lorentz transformation you also multiply coordinate time. Just plug in some numbers and you'll see. :smile:
  • #53
Dear harrylin, not that I want to argue with you, but how can we multiply coordinate time? As I understand it,
Coordinate time is, for example, July, 2nd 2015 18:00:00 and,
Proper time is, for example, 20 seconds.
What would be if you multiply July, 2nd 2015 18:00:00 by two? January 5,th 2031 12:00? Of course if you count start time is January 1st 1 CE 00:00. Correction it would be January 5,th 2030 12:00, because CE start at 1 not at 0 year. (or if we want the start time from the big bang 13 billion years ago, well...) Of course if you multiply July, 2nd 2015 by two FROM July 1st, 2015 than, it would be July 3rd 2015.
So, I think, just like vector and coordinate that I learned at high school (or junior high?) we can only multiply (July 2nd 2015 MINUS July 1st 2015) by two, then we can get answer. And the answer is proper time. And if we add that proper time to July 2nd, then again, we'll have coordinate time again.
And if I understand it correctly, if I treat proper time and coordinate time just like vector.
Is this right?
A. Proper Time + Proper Time -> Proper Time
B. Proper Time - Proper Time -> Proper Time
C. Proper Time * constant -> Proper Time
D. Proper Time / constant -> Proper Time
E. Coordinate Time + Proper Time -> Coordinate Time
F. Coordinate Time - Proper Time -> Coordinate Time
G. Coordinate Time + Coordinate Time -> ??
H. Coordinate Time - Coordinate Time -> Proper Time [EDIT: Coordinate Time]
I. Coordinate Time * constant -> ??
J. Coordinate Time / constant -> ??
  • #54
Proper time is, for example, 20 seconds. [..]
That understanding was wrong.
Coordinate time is the time (of a clock, or calculated) that is related to a reference frame. For example, July, 2nd 2015 18:00:00 GMT is a coordinate time of a time zone of the ECI frame. When you use it in equations, you simply count the number of days or seconds (or years) from a convenient reference time. Thus coordinate time is often handily chosen to be 0 seconds at the start time t0, and after 20 seconds we then have t1=20 s.
On the other hand, proper time is simply the "time" indicated by a clock in whatever state of motion.
See for example http://www.iep.utm.edu/proper-t/ , sections 3 (coordinate systems) and 15 (Time and Space Dilation). The Lorentz transformations compare time ("coordinate time") of two inertial reference systems in relative motion, and the proper time of a clock that is comoving with a reference system does not need to differ from the coordinate time of that reference system at that position.
  • #55
harrylin said:
That understanding was wrong.[..]
See for example http://www.iep.utm.edu/proper-t/ , sections 3 (coordinate systems) and 15 (Time and Space Dilation).[..]
Okay, okay. I click the link. Mentz114 has given me some link in Wiki, but I'm still studying Post 17, that's why I didn't click the link.
  • #56
In relativity, proper time along a timelike (or lightlike) world line is defined as the time as measured by a clock following that line.
So, supposed if there is an astronout (A) wearing a red wrist watch, and he moves at 0.6c as shown in green world line.
And a rest observer (R) is staying in his room with a brown floor clock
So the proper time for (A) is shown by the red clock, because the red clock is moving with (A), if supposed (A) can see brown clock, it's not (A)'s proper time because brown clock ticks at different rate than the red clock. Is this something like that?
http://www.iep.utm.edu/proper-t/#H3The essence of the Special Theory of Relativity (STR) is that it connects three distinct quantities to each other: space, time, and proper time. ‘Time’ is also called coordinate time or real time, to distinguish it from ‘proper time’. Proper time is also called clock time, or process time, and it is a measure of the amount of physical process that a system undergoes. For example, proper time for an ordinary mechanical clock is recorded by the number of rotations of the hands of the clock. [..]
[EDIT: INSERT]
This invariance principle is fundamental to classical physics, and it means that in classical physics we can define: Coordinate time = Proper time for all natural systems. [..]
However, the distinction only gained real significance in the Special Theory of Relativity, which contradicts classical physics by predicting that the rate of proper time for a system varies with its velocity, or motion through space. The relationship is very
[EDIT]
[..]the faster a system travels through space, the slower its internal processes go. At the maximum possible speed, the speed of light, c, the internal processes in a physical system would stop completely. Indeed, for light itself, the rate of proper time is zero: there is no ‘internal process’ occurring in light. It is as if light is ‘frozen’ in a specific internal state.
So, I want to ask something here,
-"The faster a system travels, the slower its internal processes go."
-"Proper time is also called clock time, or process time, and it is a measure of the amount of physical process that a system undergoes"
But for the system itself, its one second is still one second right? All we know for 1 second is the tick of the second hand that moves 60 at our desk, altough as I have often heard in this forum, we are traveling near the speed of light according to LHC.
Do I get it right?
Likes Mentz114
  • #57
Yes, that's the right idea.
This reference seems unclear and a bit muddled to me. I'd stick with the Wiki definition. It's also worth looking at the SI definition of the second, from NIST, http://physics.nist.gov/cuu/Units/current.html. The SI second measures proper time.
The second is the duration of 9 192 631 770 periods of the radiation corresponding to the transition between the two hyperfine levels of the ground state of the cesium 133 atom.
When you can carry out this definition precisely as written (well, you're actually allowed to ignore any/all of the quantum issues, SR is a classical theory), and actually count the number of vibration periods of some hypothetical cesium-133 atom undergoing the specified transition, you are measuring proper time.
Note that you need to specify what is called a worldline (a particular path through space-time), to measure the proper time. The "twin paradox" is an example of how two cesium atoms traveling diferent paths can start and end at the same pair of events, but experience different amounts of proper time on their journey.
It's also worth noting what proper time does not measure. Proper time has no concept of "now", it does not specify a mechanism of synchronizing clocks. Any measurement which requires clocks synchronization to be performed is not a measurement of proper time.
  • #58
That is close. The brown clock is blue's proper time. Every clock shows the time along its own worldline.
Your diagram shows the proper times of both observers.
Do I get it right?
Locally one second is always one second and the speed of light is always c. No one notices any relativistic effects on their own clocks or rulers.
Likes Stephanus
  • #59
Dear pervect, dear PF Forum,
Thanks for you answer. I really appreciate it.
Finally...:olduhh:
This reference seems unclear and a bit muddled to me. I'd stick with the Wiki definition. [..]
When you can carry out this definition [..]and actually count the number of vibration periods of some hypothetical cesium-133 atom undergoing the specified transition, you are measuring proper time.
So, what I mean is this.
Even if we travel fast and "The faster a system travels, the slower its internal processes go.", but 1 second for us is:
- "The second is the duration of 9 192 631 770 periods of the radiation corresponding to the transition between the two hyperfine levels of the ground state of the Cs 133 atom.", or
- The movement of the second hand clock for 60 clockwise (of course)
For a rest observer watching us moving, our clock is slower, but we still doesn't feel any different compared than we are at "rest", do we. The clock in our wristwatch, the atomic clock that (supposed) we carry, everything works "normal".
I'll contemplate this.
Thanks for the answers.
  • #60
Mentz114 said:
That is close.
Finally...:oldeyes:
As long as the clock moves along with the observer, right?
I want to ask something here.
Okay,... Blue and green move at the same velocity.
1. Can we say that blue and green are at the same frame of reference?
2. G2 will see Blue as B2, and B1 will see Green as G1, is this true?
3. If number 1 is true, can Blue use Green time as proper time?
Of course. I completely understand that.
Thanks.
  • #61
Stephanus said:
Finally...:oldeyes:As long as the clock moves along with the observer, right?I want to ask something here.
Thanks.
It is not strictly true to say that something is 'in' a frame of reference. The whole world covered by the coordinates is 'in every frame'.
Green and blue are comoving, They have zero relative velocity, ##\gamma=1## and so their clocks and rulers are the same..
From your diagram we can say that if green sends a beam of light to from G1 to blue, it arrives at event B1. If blue sends a beam from B2 it arrives at event G2.
This scenario tells you more. You can see a symmetry between green and blue because the are comoving. From any frame the times on the clocks of green and blue at all the events will be the same, 0 for B2 and G1, and 6 for B1 and G2. All proper times are invariant.
Likes Stephanus
  • #62
Dear PF Forum,
Thanks for any helps for me so far.
But I still have questions, that I need confirmation.
If we have two observer (B) Blue and (G) Green.
- They are at rest,
- Clocks are synchronized (is this related to our discussion? I don't think so, but I'll write anyway)
- Then at a preagreement time, G moves toward B at 0.6c ##\gamma = 1.25##
What is the correct way to draw the ST diagram?
or
Because "they" said that for the moving object the length is contracted, but then again I remember
harrylin said:
A little elaboration: suppose that at CERN in Geneva a particle is accelerated to 0.99999c in the direction of Lyon. Does that contract the distance between Geneva and Lyon?
or
I purposedly add the wider green world line (see red circle), because "they" said that for a moving object, there is simultaneity of event. So the "distance between Geneva and Lyon is not contracted", but Green does have already moved several distance when Blue receive event G, see the wider green line.
And in Picture 4, I tried to draw light rays, but there is something that doesn't make sense.
I drew light cones for events on Green world line, namely
G-3, G-2, G-1, G0, G+1, G+2, G+3. Each one representing each second for Green. And each event on green world line corespond to Blue world line
G-3 -> B-3
G-2 -> B-2
G-1 -> B-1
G -> B
G+1 -> B+1
G+2 -> B+2
G+3 -> B+3,
But if Green moves, it seems that even if G-1, takes place before G+1, but B+1 takes place before B-1. Where did I go wrong?
Please see the zoomed picture 4b.
I could have quoted Sherlock Holmes dictum, "If you leave all the impossible, the remains however improbable is the correct answer", then I'll choose Pic 1. But then again, where is the length contraction in Pic 1?
Thanks for any help
  • #63
Do I get it right?
Yes you got it right. :smile:
Note however that you have put only part of a phrase in bold, the phrase is wrong for SR:
Likes Stephanus
  • #64
Stephanus said:
Dear PF Forum,
- They are at rest,
Yes, that is the correct diagram.
After that I cannot understand what you are doing. It is alarming that you still think the objects are moving in the time direction. Have you tried the 'Animate' feature ?Length cotraction is the projection of the x'-axis in the x-axis. I'll try to do a diagram.
[Edit]
My diagrams are wrong. I cannot show length contraction on the diagram right now.
  • #65
Thanks
I do animate feature before, but not for this. Now I have. But I can't still make it sense. But your previous answer has explained enough for me. Now I know the correct diagram.
It's okay. Take your time
  • ST-04.txt
  • #66
Stephanus said:
ThanksI do animate feature before, but not for this. Now I have. But I can't still make it sense. But your previous answer has explained enough for me. Now I know the correct diagram.
The diagram you sent me does not agree with your scenario. Pic 1 of post#62 is correct, if green is one object.
The x-axis is like a long straight street. One can only move up the street or down the street. The time axis shows the clock-times for the clocks in the street.
You seem to be making it complicated when it is simple.
You are also jumping around again. Length contraction is taken care of by the LT. Leave it until you understand ... something.
  • #67
Thanks Mentz, for your clarification.
Actually these are my diagrams. Those are without light rays.
ST-01 is for Pic 1, and ST-02 is for Pic 2.
  • ST-01.txt
  • ST-02.txt
  • #68
There is something very wrong. When I load those diagrams they look fine. But when I boost with 'match speed' - it boosts with v instead of -v !
Also when I try to animate it is as if the worldlines do not exist - the animation is empty.
If I plot a similar diagram - it works fine. Please try loading this and try 'animate'. I'd like to know what happens. In the meantime don't believe anything the plotter is doing.
  • ST-l1.txt
  • #69
"Don't believe anything the plotter is doing??"" Oh, I'm so sorry Mentz114. It's not a bug.
I edited the text file!
This software is very good, but what troubles me is the resolution. So, I worked out the coordinate in Microsoft Excel and I edit the text file, and I load the text in the plotter.
For x coordinate it is 300 + x*20
For t coordinate it is 300 - t*20
Then I get the picture, then I save it to bitmap.
It's completely my fault. I'm afraid it's the resolution.
  • #70
Again, my bad quoting habit. Next time, I'll try not to mislead the meaning of a paragraph. Thanks harrylin.
