Measuring magnetic field of a solenoid
To measure the magnetic field in a solenoid, a common method involves using a Hall Probe, which measures the magnetic field directly. A standard high school experiment can determine the magnetic field inside a solenoid but may have about a 10% error margin. For a school assignment, it's essential to understand the setup, including the orientation of the Hall bar, which should be aligned correctly with the solenoid's axis. Alternatively, an induction experiment can be designed to measure the induced EMF from a moving solenoid. Understanding these methods will help in accurately measuring the magnetic field.
Majid
hi
I need an experiment to measure magnetic filed in a solenoid.
could anyone help me?
Make a solenoid, crank it up to 50 Amps, and stick a probe in!
Is this a school assignment, or just personal interest? Is it something you want to actually carry out, or do you just want to know how it's done? THere are a couple of ways to do it; there is a "standard" high school experiment that determines the magnetic field inside a solenoid, but it has about 10% error.
Typically the longitudinal direction of of the Hall bar in a Hall probe is parallel to the length of the probe. So, if you stick a probe into a solenoid, wouldn't the Hall bar be pointing the wrong way (along the axis of the solenoid) ?
Dear chi meson
This is a school assignment. can you explain that "standard" high school experiment that determines the magnetic field inside a solenoid?
Thank You.
Majid, you typically use a Hall Probe to measure B-fields. In the absence of a Hall Probe you could design an induction type experiment and measure the induced EMF due to a solenoid moving at some known rate.
Susskind (in The Theoretical Minimum, volume 1, pages 203-205) writes the Lagrangian for the magnetic field as ##L=\frac m 2(\dot x^2+\dot y^2 + \dot z^2)+ \frac e c (\dot x A_x +\dot y A_y +\dot z A_z)## and then calculates ##\dot p_x =ma_x + \frac e c \frac d {dt} A_x=ma_x + \frac e c(\frac {\partial A_x} {\partial x}\dot x + \frac {\partial A_x} {\partial y}\dot y + \frac {\partial A_x} {\partial z}\dot z)##. I have problems with the last step. I might have written ##\frac {dA_x} {dt}...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
