iScience
- 466
- 5
Is measuring pressure for a compressible fluid system angle dependent?For a compressible fluid, Bernoulli's Law gives us a relation between two points along a closed system. More specifically it gives us the relation between two cross sections belonging to two distinct points in the closed system.
But I'm curious about the cross section itself for any given point in a closed system.
Consider:
A closed system of compressible fluid moving about smoothly (laminar flow).
The system has four straight edges and four corners resembling a rectangle while maintaining a uniform cross sectional area throughout the system.
Along the edges I expect no difference in velocity and pressure within the cross section of any given point (along the edges). But for a corner cross section there should be a velocity and pressure gradient (right?).If this is correct, does this mean pressure measurements taken at curvature points are angle dependent?
Consider:
