Mechanical Principles. Engineering Components
To calculate the ultimate tensile stress (u.t.s) for a mild steel specimen with a maximum load of 94kN and a diameter of 12mm, the formula for stress (Force/Area) is applied. The ultimate tensile stress is a material constant and does not depend on the specimen's dimensions. For a 36mm diameter bar, the working stress is determined by applying a factor of safety of 4, meaning the maximum allowable stress is one-fourth of the ultimate stress. This allows for the calculation of the greatest allowable load by rearranging the stress formula. Understanding these principles is crucial for accurate engineering assessments.
kyleblack
Hi i am need of some help with a Mechanical Principle question.
The Question
The maximum load in a tensile test on a mild steel specimen is 94kN. If the test piece is 12mm diameter calculate the ultimate tensile stress.
(u.t.s) What is the working stress and greatest allowable load on a 36mm diameter bar? Use a factor of safety of 4.
I have n idea how to answer this question.
The Question
Stress is just Force/Area
Then you know the stress the steel can take before it breaks (it should be yield strength instead of ultimate however, since I think the maximum force occurs right before the sample begins to yield), so you can then use that to find the force it would take to duplicate that force in the sample.
Then apply the safety factor... Done.
The ultimate tensile stress is independent of the force and dimensions of a particular material. It is relatively a constant determined bythe material. For example, a piece of Alumnim - T6061 with a diameter of 12 cm has the same ultimate tensile stress as a similar piece with a diameter of 1264213 km. Granted that stress is Force/Area, the larger piece will be able sustain a much larger force. You can just look that number up online for the particular alloy of steel you are using as steel is quite common.
For a factor of safety of 4, this means the maximum allowable stress on the specimen must be 1/4 the ultimate stress. So if the ultimate stress was 40 Mpa, then the maximum allowable stress would be 10Mpa. Then we just set 10Mpa = Force (MegaNewtons)/ Area (meters^2). you know the diamater in mm so you'll need to do some basic converting. You can then solve this equation for the force (which will come out in MegaNewtons) and then convert that to whatever you need.
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
TL;DR Summary: Heard in the news about using sonar to locate the sub Hello : After the sinking of the ship near the Greek shores , carrying of alot of people , there was another accident that include 5 tourists and a submarine visiting the titanic , which went missing Some technical notes captured my attention, that there us few sonar devices are hearing sounds repeated every 30 seconds , but they are not able to locate the source Is it possible that the sound waves are reflecting from...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
