Mechanical Waves On a String - Speed, Amplitude, and Power
The discussion centers on calculating the speed and amplitude of a wave on a string under specific conditions. The string has a mass of 38.5g, a length of 5.60m, and is under a tension of 220N, with a wave frequency of 178 Hz. The correct speed of the wave is determined to be 179 m/s, while the amplitude is calculated to be 1.35 cm. The initial calculations were incorrect due to a conversion error in the mass from grams to kilograms. The participant successfully identifies and corrects the mistake, leading to the accurate results.
Nickg140143
A string of mass 38.5g and length 5.60m is secured so that it is under tension of 220N. A wave with frequency 178 Hz travels on the string. Find the speed of the wave and the amplitude of the wave if it transmits power of 140 Watts.
The Given answers are: 179 m/s and 1.35 cm
I believe these are the main equations that I can use to solve these problems
speed of wave
v=\sqrt{\frac{Tension}{\mu}},\mu = \frac{Mass}{Length}
Power (from my notes)
P=\frac{\mu \times v \times \omega^2 \times A^2}{2},\omega = 2\pi f
Power (from my book, think this is average power)
P=\frac{\sqrt{\mu \times F} \times \omega^2 \times A^2}{2},\omega = 2\pi f
Are my notes correct? Are these equations for the same amount of power?
Well, I'm given mass, length and tension of the string, and If my understanding is somewhat correct, the speed at which a wave moves through a medium is dependent only on the properties of the medium itself, and for this string, these properties are the mass, length, and tension
mass(M) = 38.5 g(grams) \longrightarrow .385 kg(kilograms)
tension(T) = 220N(\frac{kgm}{s^2})
length(L)=5.60m(meters)
With this information, I can use my formula for velocity of the wave to find the speed of the wave.
I'll calculate \mu
\mu = \frac{M}{L} \longrightarrow \mu = \frac{.385 kg}{5.60 m}=0.069\frac{kg}{m}
Now v
v=\sqrt{\frac{T}{\mu}}\longrightarrow v=\sqrt{\frac{220\frac{kgm}{s^2}}{0.069\frac{kg}{m}}}=\boxed{56.5\frac{m}{s}}
Since I now have the velocity v, I should use the equation for power P, where P = 140 watts(\frac{kgm^2}{s^3}) and solve for A
but before I can use this, I need \omega, which is \omega = 2\pi \times frequencey(f)
\omega = 2\pi(rads) \times 178 \frac{1}{s}=1118.41\frac{1}{s}now that I have \omega, I can solve for A
140\frac{kgm^2}{s^3}=\frac{(0.069\frac{kg}{m}) \times (56.5\frac{m}{s}) \times(1118.41\frac{1}{s})^2 \times A^2}{2}
\frac{280\frac{kgm^2}{s^3}}{(0.069\frac{kg}{m}) \times (56.5\frac{m}{s}) \times(1118.41\frac{1}{s})^2}=A^2
A^2=5.74\times 10^{-5}m or 0.0000574 m \longrightarrow \boxed{A=.0076m \rightarrow .76cm}But as you can see, these answers do not correspond with those that are given. There are plenty of concepts that I'm struggling with here in physics, so I want to make sure I'm not straying too far off the path here.
any help would be greatly appreciated.
Found my problem...
.385kg
This mass should actually be
.0385kg
Looks like I simply messed up on a conversion.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
