Mechanical Waves Recorded after an Earthquake
The discussion revolves around calculating the distance from a seismic station to the earthquake's center using the recorded times of transverse and longitudinal waves. The transverse wave is recorded 10 seconds after the longitudinal wave, with speeds of 300 m/s and 500 m/s, respectively. Participants emphasize the importance of showing prior thought on homework problems before seeking help. The approach involves setting up an equation based on the relationship between distance, speed, and time. The conversation highlights the educational practice of guiding rather than directly solving problems for learners.
Harli
New poster has been reminded to show their work on schoolwork problems
A seismic station records the transverse wave 10s after recording the longitudinal wave. Find the distance of the seismic station from the center of the earthquake.
V transverse=300m/s
V longitudinal=500m/s
f=1/T or f=N/t
λ = v/f
Hint: How do speed, distance, and time relate to each other?
Harli said:
Homework Statement:: A seismic station records the transverse wave 10s after recording the longitudinal wave. Find the distance of the seismic station from the center of the earthquake.
V transverse=300m/s
Relevant Equations:: f=1/T or f=N/t
λ = v/f
Let, V transverse be v1 and V longitudinal be v2.
If 'd' is the distance of the seismic station from the center of the earthquake, we have -
d/v1 - d/v2 = 10...solve for d!
Hi @raawe. Welcome to PF. You have made the same mistake that I did when I arrived here!
If anyone asks for help with homework, they need to show that they have already thought about about the problem. See point 4 in the guidelines: https://www.physicsforums.com/threads/homework-help-guidelines-for-students-and-helpers.686781/
So we typically 'steer' people, rather than directly solve their problem. Often that involves a series of questions and answers. That's why @Doc Al replied as in Post #2.
Likes berkeman and Doc Al
My apologies. I will take from now.
Likes Tom.G, berkeman and Steve4Physics
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
