MHB Mechanics- connected particles
The discussion revolves around calculating the maximum mass of passengers in a lift with a mass of 500 kg, a breaking tension of 12,000 N, and a maximum acceleration of 0.75 m/s². When accelerating upwards, the maximum mass of passengers is calculated to be 616 kg, while during downward acceleration, it is 797 kg. Using the average mass of a person at 75 kg, the maximum number of passengers allowed is determined to be 8. Participants emphasize the importance of sharing solutions to benefit the community. The calculations illustrate the balance of forces acting on the lift during different acceleration scenarios.
Shah 72
MHB
A passenger lift had mass 500 kg. The breaking tension of the cable is 12000N. The max acceleration of the lift is 0.75 m/s^2
a) if the lift travels at its max acceleration, calculate the max mass of the passengers:
1)when the lift is accelerating upwards
2) when the lift is accelerating downwards
b) taking the average mass of a person to be 75 kg, what is the max number of passengers that should be allowed to travel in the lift?
Mathematics news on Phys.org
What have you accomplished with this one?
So it should be T- mass of lift× g- mass of passengers ×g= ( M+m) ×a
Iam not getting the right ans that is mentioned in the textbook
Thank you so much! I got the answers
Are you going to share your solution so others may benefit?
That’s a big part of being a member of MHB. Get some help … give some help.
Ofcourse.
So I did T- Mg-mg=(M+m)×a
I got M=616kg
b) T- Mg-mg= -(M+m)×a
m=797 kg
2) I did 616/75= 8 people
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
