MHB Mechanics- connected particles
Two particles, A (8 kg) and B (5 kg), are connected by a string over a pulley and released from a height of 1.2 m. When particle A hits the ground, it does not bounce, and particle B reaches a maximum height of 2.68 m. To find the time until B hits the ground after A's descent, the acceleration of the system can be calculated using the tension equations. The upward velocity of B when A reaches the ground can be determined, followed by calculating the time it takes for B to fall under gravity. The discussion emphasizes the need for proper calculations to solve the problem effectively.
Shah 72
MHB
Two particles A and B are attached to the ends of a light inextensible string, which passes over a smooth pulley. Particle A has mass 8 kg and particle B has mass 5kg. Both the particles are held 1.2m above the ground. The system is released from rest and the particles move vertically.
a) when particle A hits the ground, it does not bounce. Find the max height reached by particle B
b) when particle A hits the ground, the string is cut. Find the total time from being released from rest until B hits the ground.
I don't understand how to calculate.
Mathematics news on Phys.org
I understood how to calculate. Thanks!
Iam not getting the ans for (b)
For the time when A hits the ground
V= u+at
t1= 1.02s
Max height traveled by B is 2.68.
When the string is cut, T= 0, a=-g=-10m/s^2
Iam not able to calculate.
how 😭😭
maha said:
how 😭😭
$M$ = 8kg, $m$ = 5kg, $T$ is the tension force in the string
$Mg - T = Ma$
$T - mg = ma$
Solve the system of equations for $a$, the magnitude of the acceleration for both masses. Once you find that acceleration, you can find the upward velocity of the smaller mass when the larger one hits the ground …
$v_f^2 = v_0^2 + 2a \Delta y$
At that time, the smaller mass is strictly under the influence of gravity, and one can determine the height the small mass rises above its initial height of 2.4 m, using a variation of the above equation …
$v_f^2 = v_0^2 - 2g \Delta y$
See what you can do from here.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
