Mechanisms to secure items in a box
  • Thread starter Thread starter engineeringdude
    Box
The discussion centers on the challenge of securing thin rectangular blocks in a box during automated transfer by a robot. The user seeks insights on maintaining stability in three axes while ensuring ease of access for the robotic arm. There is a request for additional project details and mechanical drawings to provide more tailored advice. The conversation hints at a possible classification of the inquiry as schoolwork, suggesting a need for clarification on the project's context. Overall, the focus remains on optimizing the design for effective automation.
engineeringdude
Hi I am having some difficulties in my design and I hope I can get some insights on this. I am using a robot to transfer a stack of thin rectangular blocks (roughly 5mm each) into a box. However, I am having some difficulties thinking how to secure the items in the 3 axis without compromising on the ease of transfer as the robotic arm have to be able to take it out and put it back in with ease. The entire process will be fully automated.
Your help is deeply appreciated! Thank you in advance :D
Welcome to PF.
Is this a schoolwork question? If so, I can move your thread to the Homework Help forums for you.
If it is for work, can you give more details about the project? Can you post your mechanical drawings so far as 3D PDF files? Thanks.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
