Baggy1
- 1
Hi!
I'v been looking into this for way too long and have come to that point where nothing makes sense, hoping you guys could help me out!![Smile :smile: :smile:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Basically i have been given a net head of 20m and need to provide a micro hydro turbine with 5kW of power for over one minute. What i want to find out is what gross head i would need to produce this and the diameter of the pipe to supply it.
I'v selected a pipe diameter of 193.67mm schedule 80 PVC for now, and these are the calculations i made:
Flow rate = 5000/0.8x1000x9.81x20 = 0.032m3/s at 80% efficiency(turbine)
Velocity = Flow rate/0.25∏x0.19^2 = 1.12 m/s
From Bernoulli's equation i have this:
sqrt(2xgx20)= 19.81 m/s is what i get for velocity
Could someone be kind enough to explain the differences in these results?
Also...
How would i work out the pipe diameter if the one i have written is incorrect? The reason i selected this size was because it would have less friction resulting in a reduced gross head length. Id have to work out the friction losses to find the gross head, this is what i did... not sure its the right way... again
I calculated the friction factor to be 0.04
Gross head - 0.04x20x1.12^2 / 0.19x2x9.81 = 20
Gross head = 20 + 0.27
Any help would be greatly appreciated
Thanks in advance
Also...
Thanks in advance
