Microeconomics questions (elasticity)
  • Thread starter Thread starter danny-saf
    Elasticity
The discussion revolves around the concept of price elasticity of demand, particularly in relation to popsicles and CDs. When the price of popsicles increased from $10 to $11, consumer expenditures dropped by 10%, suggesting that the demand for popsicles is price-elastic. Participants debated the correct calculation of price elasticity, emphasizing that it measures the responsiveness of quantity demanded to price changes. The formula for elasticity was clarified, noting that it typically results in a negative value due to the inverse relationship between price and demand. Overall, the conversation highlights the importance of understanding elasticity in microeconomics.
danny-saf
When the price of popsicles rose from $10 to $11, consumer expenditures on them dropped by 10%, indicating that:
A. Demand for popsicles had a price elasticity of -1
B. Demand for popsicles was price-elastic
C. Popsicles are a normal good
D. Popsicles are an inferior good
E. More than one answer is correct
2. At a price of $10, Jane would buy 8 CDs. At a price of $12, Jane would buy 6 CDs. Her price elasticity of demand would then be:
A. -1/2
B. -11/7
C. -5/4
D. -5/8
E. -4/5
I'm pretty sure, because price elasticitiy is a representation of the change in price/demand, and is technically expressed in a negative manner. seems to be a one-to-one ratio.
I forget if it's price over qantity or the other way around.
Econ is so easy, if you show up to the classes you shouldn't have any problems doing decently.
Price Elasticity is expressed as:
(Change in % of Quantity Demanded / Change in % of Price)
To determine the change in % of QD, you use [$1/($21/2) = ~ 9.5%]. So a change in the price of 9.5% led to a change in consumer demand of 10%
(10/9.5 = 1.05)
1.05 tells you whether or not demand is elastic or inelastic, and based on that formula you should be able to infer the answer to second question.
I took Micro last semester and when we learned elasticity it was never a negative value except for 'income' and 'cross' elasticity. Elasticity of supply & demand is a ratio to measure responsiveness, and it was always positive. So, if you're professor is using another text that teaches negatives for this measure than General Sax may be correct, and not me.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
