Milkyway Black-hole vs Andromeda Collision
In summary, black holes do not have a stronger gravitational pull than other objects of the same mass, but their compactness allows them to have an event horizon. The Milky Way galaxy will not implode due to the central black hole, and the expansion of the universe is not affected by the gravity of one galaxy.
omar1
Since black-holes are the catalyst of galaxies and black-holes nomnomnom galaxies; wouldn't it be true that the Milkyway galaxy is shrinking, taking Earth (our solar-system) with it, NOT the holamola entire universe expanding?
So, wouldn't the Milkyway galaxy implode before it would collide with the Andromeda galaxy?
Astronomy news on Phys.org
Welcome to PF omar1,
Your question stems from a common misconception about black holes. The gravity of a black hole behaves in exactly the same way as the gravity of any other object of the same mass. For instance, if you were to magically and instantaneously replace our Sun with a black hole of exactly the same mass, then the Earth and the other planets would continue on in the same orbits as though nothing had happened. The reason is because the strength of the gravity of an object depends only on the mass of that object, and your distance from it. This is as true for black holes as it is for anything else.
What's different about black holes is that they are very compact. All the matter of a black hole is compressed down to a single, infinitely dense point. So, you can get much closer to a black hole than you can to an ordinary object. The closer you get, the stronger gravity gets. Eventually, you will reach a distance at which the gravity is so strong, that nothing can escape, not even light. This boundary (defined by this distance) is known as the Event Horizon. Ordinary objects like stars and planets don't have event horizons because they are not so compact. So you can't get that close to them: not before touching their surfaces. ONLY once you get within the event horizon of a black hole is it true that you cannot escape. Outside the event horizon, you can escape if you have enough speed (just like how a spacecraft can escape the pull of Earth's gravity).
For this reason, the central black hole of the Milky Way galaxy is NOT sucking everything in, and the Milky Way will NOT impode.
One last point: the "holamola" entire universe is MUCH bigger than one galaxy, and the expansion of the universe is not affected by the gravity of just one single object.
Related to Milkyway Black-hole vs Andromeda Collision
1. What is a black hole?
A black hole is a region in space with a gravitational pull so strong that nothing, including light, can escape it. It is formed when a massive star dies and collapses in on itself.
2. What is the Milky Way?
The Milky Way is the galaxy that contains our solar system. It is a spiral galaxy with an estimated 100-400 billion stars, including our sun.
3. What is the Andromeda galaxy?
The Andromeda galaxy is the closest spiral galaxy to our Milky Way. It is about 2.5 million light years away and has an estimated 1 trillion stars.
4. What will happen when the Milky Way and Andromeda galaxies collide?
When the two galaxies collide in about 4 billion years, it is likely that they will merge to form a larger elliptical galaxy. However, individual stars are not expected to collide due to the vast distances between them.
5. Will the black holes in the Milky Way and Andromeda collide during the collision?
It is possible that the two supermassive black holes at the centers of the Milky Way and Andromeda galaxies will merge during the collision, but it is not certain. The final outcome will depend on the trajectory and speed of the black holes at the time of the collision.
  • Astronomy and Astrophysics
