MHB Min -7, Interval -6 to 0, & Find Roots of \sqrt{7}
  • Thread starter Thread starter mathlearn
    Interval Roots
The minimum value of the function is identified as -7, and the function is increasing in the interval -6 < y < 0. The roots of the equation x^2 - 4x - 3 = 0 are found using the quadratic formula, yielding approximate values of x = 2 ± √7, with √7 estimated to be about 2.6. A point of intersection for the line y = 0.5x and the quadratic function is determined to be near (-0.6, -0.3). The increasing interval for x is confirmed to be approximately 3 < x < 4.6.
mathlearn
Hi,
I drew the graph
1. Minumum value of the function = -7
can you help me to write the values for which the function is increasing interval -6<y<0
also can you help me to find the roots of the equation and obtain $$\sqrt{7}$$ to the nearest decimal place.
Help me to proceed
Many Thanks (Smile)
Mathematics news on Phys.org
Can you post an attempt? Also, this should have been posted in the geometry sub-forum.
I .First I drew the graph ✔
II.The first question asks the minimum value which I found using the graph '-7' ✔
II. Interval
IV. (an attempt) When y=0 roots -0.6 and 4.7
y = x2- 4x -3
0 = x2- 4x -3
Can you help me to find the $$\sqrt{7}$$ to the nearest decimal place and the values of the function for which x is increasing the in interval -6<y<0
Many Thanks (Smile)
IV.
For $ax^2+bx+c=0$, the quadratic formula for $x$ is
$$x=\dfrac{-b\pm\sqrt{b^2-4ac}}{2a}$$
so we have
$$x^2-4x-3=0\implies x=\dfrac{4\pm\sqrt{28}}{2}=2\pm\sqrt7$$
Referring to your graph, $2+\sqrt7\approx4.6$, so $\sqrt7\approx2.6$.
Can you now attempt III, using the above result for the positive root of $x^2-4x-3=0$?
Can you explain on $$\sqrt{7}+2$$ on the RHS of the equation . and How did this happen? Can you explain :)
Referring to your graph, 2+$$\sqrt{7}$$≈4.6 , so $$\sqrt{7}$$≈2.6.
Many Thanks :)
$$x=\dfrac{4\pm\sqrt{28}}{2}=\dfrac{4\pm\sqrt{4\cdot7}}{2}=\dfrac{4\pm2\sqrt7}{2}=2\pm\sqrt7$$
O.k?
I agree :) but what I'm uncertain is of how did you get 2 +$$\sqrt{7}$$ to be 4.6, What was referred in the graph to derive that?
Many Thanks :)
Look on the positive x-axis, where y = 0. :)
:) So to sum up the way of finding the $$\sqrt{7}$$using the graph.
1.Use the quadratic formula on the function
All of the rest of steps are clear and you have shown in a very detailed manner how the substituted quadratic formula is equal to $$\sqrt{7}+ 2$$.
*What do you call this method of equaling the "top right part of the quadratic formula to a simplified top right part "
and my other question is why did you pick the positive x-axis instead of the negative ?
Many Thanks :)
Simplification, I guess.
mathlearn said:
...and my other question is why did you pick the positive x-axis instead of the negative ?
I could have picked either; the positive x-axis seemed easier and clearer at the time.
:) Now help me do V
(v) by drawing a suitable straight line, write down the coordinates of a point on the graph of which the x coordinate is twice the y coordinate.
Using Desmos I drew a graph https://www.desmos.com/calculator/sfxxgenmpz
Can anyone help me
_______________________________________________________________________________________________________Also help me in III
write down the interval of values of x for which the function is increasing in the interval −6 < y < 0.
Many Thanks :)
A hint for V: $y=\dfrac12x$
:) Many Thanks,
I drew a straight but i don't no whether it's correct
Can anyone comment
Many Thanks :)
V:
Use Desmos to graph $y=x^2-4x-3$ and $y=\dfrac12x$, then try to approximate the point of intersection of the two graphs.
Do you understand why the equation $y=\dfrac12x$ is useful? In fact, we can precisely determine the point of intersection of the two graphs by solving
$$x^2-4x-3=\dfrac12x$$
for $x$ and then finding $y$.
greg1313 said:
V:
Drew the line $$y=\dfrac12x$$ and updated the graph in desmos.
[graph]cprxgj0agr[/graph]
But I don't see an perfect point of intersection :)
greg1313 said:
V:
So after simplification it gets [multiply both sides by 2 to cancel the 2 in the denominator of the fraction on RHS]
$$2x^2-8x-6=x$$
So $$x=1$$ I guess
$$\therefore \displaystyle y=\dfrac12x$$
$$\displaystyle y=\dfrac12*1$$
$$\displaystyle y=\dfrac12$$
So There after , I don't seem to get it that much
Many Thanks :)
From $2x^2-8x-6=x$ we get $2x^2-9x-6=0$. Can you continue?
Looking at your hand-drawn graph, the point of intersection of $y=\dfrac12x$ and $x^2-4x-3$ is near $(x,y)=(-0.6,-0.3)$.
Yes absolutely :)
points of intersection (-0.6,-0.3); Correct ? ✔
Many Thanks :)
Now can you help me on
(iii) write down the interval of values of x for which the function is increasing in the interval −6 < y < 0.
That should be correct if you're expected to use the graph you drew. If you're expected to provide an exact value you need to solve the quadratic equation I gave in my previous post.
Very good.
Can you help me to find the interval.
Many Thanks :)
Any thoughts on how to begin?
I marked the range in orange
I think it should be 3<x<4.2, I am having trouble in writing the range
Any Ideas ?
Many Thanks :)
Your orange line is correct. $x\in(3,4.6)$ or $3<x<4.6$, depending on which notation you are expected to use.
Many Thanks (Smile)
