B Misleading Textbook Equation for vf^2=vi^2 + 2ad
  • B
  • Thread starter Thread starter PhysTeacher88
    Kinematics Textbook
The discussion critiques the textbook equation vf^2=vi^2 + 2ad for uniform acceleration, noting its lack of vector representation, which can lead to confusion in problem-solving. The author highlights that treating acceleration and displacement as scalars can yield incorrect negative distance values in certain scenarios, such as a ball thrown upward. A response clarifies that the initial velocity is positive while acceleration is negative, emphasizing the importance of direction in one-dimensional motion. The equation is identified as a special case of the work-energy theorem, which is scalar in nature. Overall, the conversation raises concerns about the potential oversight in teaching this equation without vector consideration.
PhysTeacher88
The textbook (Nelson 11) at my school lists the "big 5" equations for uniform acceleration. In all but one, they use vectors.
For vf^2=vi^2 + 2ad, the opt not to use vectors.
Is there a deep reason why we would not want to use the vectors?
I understand that when you square the velocity, the direction information is lost, however, without making the acceleration and the displacement vectors (textbook reads distance because it's not a vector), students will not get questions like this correct:
A ball is thrown up at 10m/s, how high will it go?
If I treat everything as scalar, we get:
(0m/s) = (10m/s)^2 + (9.8)d
the distance ends up being a negative value, which is clearly not true given the context.
If they at least made the "a" and delta "d" vectors, they would not run into this problem.
I'm guess they took this formula from conservation of energy, rather than thinking about this from a kinematics perspective.
Am I missing something, or is this an oversight?
Cheers,
K
Cheers,
K
What you're missing is that you have the initial velocity, ##v_i##, being positive, which means that ##a## must be negative. So here ##a = -9.8 m/sec^2##.
Also, the probable reason for not using vectors is that they are dealing with motion in one dimension.
It’s a special case of the work-energy theorem which is a scalar equation.
ΔKE= net Work (=F⋅d for constant F)
Correct.
Also, notice that d also have a sign. It is positive if the motion was upward, and negative if the motion was downward.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
