Mixing chamber with multiple inlets
The discussion revolves around solving a problem involving a mixing chamber with multiple inlets, focusing on mass and energy balance equations. The participants clarify that the mass flow rates must satisfy the equation m1 + m2 = m3, while the enthalpy conservation equation m1*h1 + m2*h2 = m3*h3 is also essential. There is confusion regarding the outlet velocity and its relevance, ultimately concluding that it was unnecessary for the calculations. The correct enthalpy values for the substances involved were confirmed, leading to the realization that the valve created a throttling process where enthalpy is conserved. The final consensus is that the velocity and certain pressure details were extraneous to solving the problem.
canadiansmith
Hi I was wondering if someone could help me with this question. Question 4 uploaded in picture.
Ok, so far this is what I have found
Pipe 1:
m1=2kg/s
P1=1000kpa
T1=100 C
h1=334.82kJ/kg
Pipe 2:
sat-liquid
T2=60 C
P2= 1000kpa
h2=291.36KJ/kg
Outlet:
sat vapor
P3=1000kpa
V=20 m/s
h3=267.97 kJ/kg
v3= 0.0202 m^3/kg
and I know that the mass in = mass out
so m1 + m2 = mout
My problem is that I don't know what to do with the velocity because I do not have area to use formula Vout=VA
Also I believe to solve the problem the formula m1*h1 + m2*h2 = m3*h3
but I have tried a variation of this and it did not work.
Enthalpy is conserved for each input, right. That's because dH = dQ + Vdp, dQ = 0, dp = 0. So you have m1h1 + m2h2 = m3h3. You also have m1 + m2 = m3. In other words, you've already stated all the equations you need.
Two equations, 2 unknowns (m2 ans m3). Outflow = m3*V.
I'm not claiming total knowledge here - does anyone see any flaws in this?
I have tied to use that method which would be
m1h1 + m2h2 = (m1 + m2)h3
but then m2 = -5.716 and this is wrong
I don't now how to relate the velocity into the equation. You said that outflow = m3*V right? what would outflow be? wouldn't the units be like kgm/s^2 or something like that?
My apologies. I did not think when I wrote that outflow = m3*V. Outflow should be just m3.
Something bothers me. Your enthalpy at the outlet is less than the enthalpy at inlet 2. That sounds weird. At 2 we have saturated liquid, and at 3 we have saturated vapor , so h3 must be > h2, yet you have h3 < h2. h3 looks OK since its temp. is 100 vs. 60 for the other two, so its h should be the highest of all.
I don't know what to do with V, if it's a red herring or needed. Must think more.
EDIT:
To conserve energy, looks like h3 should be reduced by ρV^2 where ρ = density at outlet.
BTW your insert is really hard to read, at least on my display.
Actually I believe the h3 value is correct because r-134a at 1000kpa the saturation temp is only 39.39 C and the sat vapor value in the table hg= 267.97. The numbers are much less intuitive because it is not water. Still confused by this velocity given. It feels like It is a necessary piece of info but without area of pipe or diameter I can't seem to do anything with it.
According to my table, saturated liquid enthalpy of r134a at 1 MPa is 105.29 kg/kJ, not 291.36. The table agrees with your T = 39.39C and sat. vapor h of 267.97.
http://energy.sdsu.edu/testhome/Test/solve/basics/tables/tablesPC/pSatR134a.html
I don't see how inlet 2 can have T = 60C and p = 1 Mpa. There's something fishy about that. As you can see from the table, and as I believed a priori, there is one and only one temperature associated with saturated r134a at 1 MPa, and that is 39.39C. I wonder if there is something tricky about the statement "after the valve", though I sure can't see it.
Sorry is this better?
Oh my bad you are very correct. I read the table wrong. I believe the pressure at inlet 2 is so high due to the valve.
hmm. I'm not sure. Like there shouldn't be. min to valve should = mout
Much! Thanks.
Ok I got it. So h3 will be 267.97 because it is sat vapor at 1Mpa and h2 will be 137.42 which is the sat-liquid value for 60 C at a pressure of 1681.3 Kpa. And because the hin = hout of a valve this can be used. Plug all this in the the formula we talked about and a got the right answer. Thanks for your help and for your time.
You absolutely got it. I was just writing to point out that the valve made it a throttling process with h conserved. Good going!
PS so V was never used?
Nope. I guess it was to throw you off as well as the pressure at p2 after the valve was never used. I hate extra info that that. Thanks again
