Möbius transformation, 3 points
usn7564
Find the Möbius transformation that maps
0 -> -1
1 -> infinity
infinity -> 1
w = f(z) = \frac{az + b}{cz+d}
Theorem:
Let f be any Möbius transformation. Then
i, f can be expressed as the composition of a finite sequence of translations, magnifications, rotations and inversions.
ii, f maps the extended complex plane one-to-one onto intself.
iii, f maps the class of circles and lines to itself
iv, f is conformal at every point except its pole
My first idea was to attempt to solve it as a normal system of eq's but that quickly falls apart due to infinity being there. Been toying with the idea of using the fact that lines will map to lines or circles but don't quite know how to apply it.
And yes I know there's a formula for these exact types of questions but it's in the next sub chapter, book figures it's possible to do without knowing that. Just can't for the life of me figure it out.
Start with 0 -> -1. This gives you relation between b and d. Then simply think in limits, when f(z) -> inf, f(z) -> 1?
Likes 1 person
Got it to work, was a bit too caught up with the fact that infinity was defined as a point (which I need to read up on more) which just messed with me. Just looking at the limits it wasn't actually bad at all.
Thanks.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
