Modeling Time to Reach Specific Pressure in Adiabatic Tire Inflation
  • Thread starter Thread starter tashkent
    Explosion Tire
The discussion focuses on developing a mathematical model to predict the time required to inflate a tire from 100 kPa to 800 kPa under adiabatic conditions, using a toroidal volume representation. Participants express confusion regarding the dimensions of the torus and how to apply relevant equations, particularly for calculating pressure changes over time. Key considerations include the tire's potential expansion, the need for a mass flow rate equation, and the impact of valve and pipe areas on pressure dynamics. The ideal gas law and thermodynamic principles are highlighted as essential for solving the problem, with a call for more specific formulas and methodologies. The conversation emphasizes the complexity of the task, indicating a need for a solid understanding of fluid mechanics and thermodynamics.
tashkent
Hi, I need a big help on how to carry on with this problem:
You witnessed the failure of a nylon rim which exploded injuring the person filling the tire with air. Develop a documented mathematical model that predicts the time required to reach a specific pressure. Your results are to be tabulated and plotted. Specifically predict the time to change from 100 kPa to 800 kPa. Assume the process is adiabatic and that the tire volume may be represented by a Torus (doughnut). In order work this problem you have to solve for pressure by iterating forwards in time.
Given:
Tire size 25 cm x 8 cm (outside diameter x width)
Rim diameter 11 cm
Air line pressure 1380 kPa
Initial tire pressure 100 kPa
Airline pipe area 32 mm2
Valve orifice area 6 mm2
Initial tire temp 16°C
Volume of torus = pi^2/4 D d^2
Area = pi^2 D d
I already got confused with what D is. Id D (25 + 11) = 36 inches or (25 - 11) = 14 inches? Then d is 16 inches because of 8 + 8 inches. HELP!
q = 0 since its adiabatic. But I can't find a formula that will harmonize pressure with time...
One needs to show more work.
Relate the dimensions D and d of a torus with those given for the tire. They may or may not be on the same basis. Most torus formulae would use the mean radius from central axis of rotation to the center of the toroidal chamber, and the minor diameter is the diameter of the circular cross-section of the toroidal chamber.
Does the tire expand? If so, some elastic energy will be stored in the tirewall.
One can increase pressure by adding mass (moles) of gas and/or increasing temperature. Adiabatic means no heat transfer across the boundary. What happens to the work done on the gas to compress it?
Hello, astronuc.
I already got the volume of the torus: V = pi^2/4 D d^2 where D is 19 cm and d is 8 cm. V is then 375 cm3.
I am assuming the tire will expand. But the big problem here is finding a math model to incorporate all the variables. These requires knowledge of thermodynamics and fluid mechanics. I'm sorry, I'm not a Mech'l. Engg. major. These students will excel in this problem.
I have a typo: air line pressure should be 1380 kPa. But I need to do time iteration to solve for pressure. I am having a hard time on figuring out what formula to use. This is not ideal gas law, its more complicated than that. Need help.
Thinking about this problem, I realized that the tire tube cross section may not be the stardard circular cross-section. The tire is 8 cm wide by 25 cm OD and 11 cm ID. So it may be more square. The volume can be found by the Theorem of Pappus, in which the volume is mean circumference (which is 2 pi * mean radius) times the area being rotated around an axis.
In this case, it is 2 pi R * A = pi D * A, where D is the average of the OD and ID, and A = 8 cm * (OD - ID)/2.
In order to calculate time, one has to calculate the rate of pressure change dP(t)/dt of the tire as the pressure increases to 800 kPa. From the ideal gas law, PV = nRT, the pressure will change (increase) as n increases, so one has to find n(t), and that depends on the mass flow rate, which itself depends in the instantaneous differential pressure between the line pressure Pl and the tire pressure P(t). One may assume the line pressure is constant.
See if one can develop the solution.
There should be a pressure drop coefficient for the area reduction associated with the valve and line.
Hello astronuc.
I don't know what mass flow rate equation to use to utilize the areas of the valve orifice and the airline pipe...
Hello tashkent,
What text is one using for this coursework? Or what lecture notes does one have that would provide some idea of flows.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
