I Modified Bessel Equation
thatboi
Hey all,
I wanted to know if anyone knew somewhere I could find the asymptotic behavior for small x (i.e x approaching 0) limit of the modified Bessel equations with complex order. The wikipedia page for Bessel functions (https://en.wikipedia.org/wiki/Bessel_function#Modified_Bessel_functions:_Iα,_Kα) provides a limit when ##|z| \ll \sqrt{\alpha+1}## but in the case of complex-valued ##\alpha## I am not sure how to interpret this bound.
Any assistance would be appreciated.
They give
##I_\alpha(z) \approx \frac{1}{\Gamma(\alpha+1)}\left(\frac{z}{2}\right)^\alpha##
just treat this as an analytic function of ##\alpha## for small z.
Paul Colby said:
They give
For the ##K_{\alpha}## limits, it is defined for ##\alpha=0## and ##\alpha>0##, so for the case of complex ##\alpha##, does this just mean ##\alpha\neq 0##?
That’s the way I read it. ##z=0## is a regular singular point and ##\alpha## is just a parameter. So it should be analytic.
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
