Modified equation of state of an ideal gas
The discussion revolves around demonstrating that the empirical temperature \zeta of a gas, defined by a modified equation of state, is equivalent to the thermodynamic temperature T using a Carnot cycle. The efficiency of a Carnot engine is expressed as η = 1 - (T_C/T_H), which relates to the temperature definitions. Participants emphasize calculating the Carnot cycle's efficiency using the provided equation of state and the first law of thermodynamics. The zeroth law of thermodynamics is referenced to explain the concept of empirical temperature and its relation to ideal gases. Ultimately, the goal is to show that \zeta can be taken as equal to T, confirming the two temperature scales coincide.
gdumont
I have this problem, it doesn't seem very complicated but I can't figure out how to do it.
A gas obeys to the equation of state
P(V-b) = Nk\zeta
where k is the Boltzman's constant. The internal energy of the gas is a function of
\zeta alone. Show that \zeta=T using a Carnot cycle.
Any help greatly appreciated
Guillaume
Any ideas?
Here is a hint to get you started.
The thermodynamic temperature T is defined in terms of the efficiency of a Carnot engine as
<br /> \eta = 1-\frac{T_C}{T_H},<br />
so what you want to do is calculate the efficiency of your Carnot cycle using your equation of state, the first law, and whatever other information may be available to you. Upon comparing the two, you will find that \zeta, which is an empirical temperature for the gas as defined by the zeroth law, is in fact equal (with a suitable choice of scale) to the thermodynamic temperature i.e. you want to find that \zeta is proportional to T.
Physics Monkey said:
\zeta [...] is an empirical temperature for the gas as defined by the zeroth law.
I don't really get why is that... any chance you can explain it to me
Thanks
I can certainly try, the zeroth law is usually taken as saying that it is possible to find a quantity, called empirical temperature, which is the same for two systems in equilibrium. This is probably fairly obvious, and it can be more or less rigorously shown using the zeroth law. The experimental observation that PV is constant in the limit of a dilute gas allows us to identify PV as being proportional to an empirical temperature for dilute or ideal gases. By defining the temperature of the triple point of water to be 273.16 K exactly, one defines the Kelvin scale in terms of an ideal gas temperature. The coeffecient then turns out to be N k so that we have the ideal gas law PV = N k \zeta. This is one way to define a temperature scale, another way is in terms of the Carnot engine where we define the thermodynamic temperature T in terms of the efficiency as \eta = 1 - \frac{T_C}{T_H}. One very basic question one can ask is, "do these temperature scales coincide?" This is the subject of your problem.
While that is perhaps all very interesting, the point of the problem is just to show that \zeta can be taken equal to T, which is defined in terms of the Carnot efficiency. To do this, you need to calculate the efficiency of your gas based Carnot engine and then compare it to the definition of T.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
