MHB Modulus problem with a negative sign
The discussion focuses on solving modulus problems with a negative sign, highlighting two methods presented in a video. The first method is traditional, while the second involves using a number line and graphing the function f(x) = |x+4| - |x| - |x-3|. The graph shows that f(x) does not intersect y = 12, indicating no solutions for f(x) = 12, while it suggests two solutions for f(x) = 2. To find these solutions, one can derive linear equations from specific points on the graph and solve for x. Understanding the second method's name would aid in further research on the topic.
Nousher Ahmed
In a video, a person discussed how to solve modulus problems with a negative sign. This is the link of that video lecture.
He showed two methods to solve the problem. The first method is commonly used. Later he showed another method where he used a number line and a graph.
Unfortunately, I couldn't understand his explanation properly. What is the original name of the second method he discussed in that video? If I could learn the actual name of the second method, I could googled to learn more about that.
Mathematics news on Phys.org
He is just plotting the function $f(x) = |x+4| - |x| - |x-3|$ using the coordinate values $(-4,f(-4))$, $(0,f(0))$, and $(3, f(3))$. He selects two more x-values, one > 3 and the other < -4, and evaluates the function at those other two to predict the behavior of the graph.
Note the graph's highest y-value is at $(3, f(3))$ ... it never gets as high as 12, indicating no solution to the equation.
Unfortunately, he doesn't say what to do if, say, $f(x) = 2$ instead of $f(x)=12$. Still, one can see by the graph there would be two possible solutions.
@skeeter , Will you please say what we could do if f(x)=2 instead of f(x)=12?
And probably for f(x)=12, still there might be two possible solutions. Will you please say what those solutions are, and how to find out those solutions?
f(x) = 12 has no solutions ... note the graph of f(x) does not intersect the horizontal line y = 12.
If f(x) = 2, I would find the linear equation of the line between the points $(0,f(0))$ and $(3,f(3))$, set it equal to 2 and solve for x.
Do the same for the linear equation of the line between the points $(3,f(3))$ and say, $(5,f(5))$ and follow the same procedure.
Thanks a lot for your cordial help.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
