Molecular Energy and Temperature: A Comprehensive Overview
  • Thread starter Thread starter mopar969
    Physics
Temperature is linked to various forms of molecular energy, including rotational, translational, and vibrational energy. The consensus in the discussion is that all these types of energy contribute to temperature, confirming that the correct answer is D. Participants express uncertainty about thermodynamics, indicating it as a challenging topic. The discussion highlights the interconnectedness of molecular energy types in understanding temperature. Overall, the relationship between molecular energy and temperature is affirmed as comprehensive.
mopar969
Temperature is associated with molecular (a) rotational energy, (b) random translational energy, (c) vibrational energy, (d) all of the preceding.
I am pretty sure that the answer is D all of the preceeding but I just wanted to check.
i guess d ... but I'm not absolutely sure (just like u.)
thermodymanics is my weak point
Thanks again for the help.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
