Molten metal temperature vs Induction Coil Current
In summary: This could be tested by monitoring voltage and current, and W, VA, VAR.In summary, the conversation discusses the phenomenon of increased coil current at the end of a cast iron melt in an induction furnace, while the power remains the same. Possible reasons for this include changes in the melt's conductivity and the effect of counter-electromotive force in electromagnetic systems. The melting process and the properties of liquid iron are also mentioned as potential factors. It is suggested that the increase in current could be due to an impedance mismatch between the melt and the generator.
gdritz
TL;DR Summary
Why does a coil current increase at the end of a cast iron melt?
Hi guys, I'm new here.
I have been analyzing the behavior of cast iron melts in induction furnaces and realized that at the end of the melt the current increases slightly. The power remains the same. Physically, does anyone know the reason?
I imagine to be related to the magnetic permeability of the metal (vs temperature), perhaps reaching a certain temperature (1540ºC is what we use) it somehow interacts with the coil. But I couldn't prove it.
Induction Furnace info:
4ton capacity
3000kW Power
Current between 2000~8000A during melt
Charge 50% steel 50% pig iron
Coil 1,70m x 0,8m , 20 turns
Excel graph attached with real data.
  • Induction.xlsx
convection of molten metal could provide those changes of conductivity.
Thanks, gave me some ideas..
But, do you mean metal magnetic conductivity or conductivity as electric current?
What would be the law of physics that applies to this phenomenon? Lorentz, Faraday? It's similar to an AC generator?
in solid phase, metal has static (low variable) properties of conductivity, but liquid one provides a lot of dynamics == for instance, convection divides molten metal into layers w/ different shares of impurities, so some layers get maximum of possible conductivity at given temp.
The material's electrons seek to minimize the total energy in the material by settling into low energy states; however, the Pauli exclusion principle means that only one can exist in each such state. So the electrons "fill up" the band structure starting from the bottom. The characteristic energy level up to which the electrons have filled is called the Fermi level. The position of the Fermi level with respect to the band structure is very important for electrical conduction: Only electrons in energy levels near or above the Fermi level are free to move within the broader material structure, since the electrons can easily jump among the partially occupied states in that region. In contrast, the low energy states are completely filled with a fixed limit on the number of electrons at all times, and the high energy states are empty of electrons at all times.
from wiki
with rising temp, more atoms lose capability to capture free Electrons + ionized atoms become carriers too. However, electrical current cannot increase ad infinitum, because of effect of eddy currents. Even DC provides fluctuations of magnetic field thanks to flows/vortexes of molten metal.
Dynamic conductors are very tricky Beasts :)
both == it's related to each other.
As the melt progresses, the surface area of metal is reduced until a single volume is present. The length of the surface path therefore shortens towards the end of the process.
I expect the electrical conductivity of liquid iron may be different to solid iron approaching 1530°C. Also the skin depth of the charge may change at the curie point near 770°C.
The London, Edinburgh, and Dublin Philosophical Magazine and Journal of Science
Series 7. Volume 44, 1953 - Issue 354. LXXX. The electrical resistivity of liquid iron, By R.W. Powell.
Pages 772-775 | Received 13 Mar 1953, Published online: 30 Jul 2010
Abstract
As a result of some preliminary experiments, which are described, the electrical resistivity of iron just above its melting point has been found to be 139 microhm cm2/cm. The resistivity of solid iron has also been measured and a value of 127·5 microhm cm2/cm is indicated at the melting point. Thus the increase in resistivity on fusion is only 9%, which is much less than would be expected on theoretical grounds and has been obtained for most other metals.
Thank you Z0dCHiY8 and Baluncore
Can the phenomenon of increased current (as well as voltage) also be related to the Counter-electromotive force ?
In electromagnetic systems everything is related. Which counter-electromotive force are you referring to?
In the original post you specified current increased slightly at the end of the cycle, while power stayed the same. That means voltage must fall. Do you monitor W = VA, and VAR ?
An induction furnace is a transformer where the furnace charge is both a lossy core and a single turn secondary.
gdritz said:
Summary: Why does a coil current increase at the end of a cast iron melt?
Perhaps it is an impedance mismatch between the now-molten (no contact resistance between individual pieces) melt and the generator output impedance. Or to put it another way, the generator could power limited and as the melt resistance goes down the voltage- current product stays constant.
Related to Molten metal temperature vs Induction Coil Current
1. What is the relationship between molten metal temperature and induction coil current?
The relationship between molten metal temperature and induction coil current is directly proportional. This means that as the induction coil current increases, the temperature of the molten metal also increases. Conversely, as the induction coil current decreases, the temperature of the molten metal decreases.
2. How does the induction coil current affect the heating rate of molten metal?
The higher the induction coil current, the faster the heating rate of molten metal. This is because a higher current produces a stronger magnetic field, which in turn generates more heat in the metal. Therefore, adjusting the induction coil current is an effective way to control the heating rate of molten metal.
3. Can the molten metal temperature be accurately controlled by adjusting the induction coil current?
Yes, the molten metal temperature can be accurately controlled by adjusting the induction coil current. Induction heating is a precise method of heating, and by adjusting the current, the temperature of the molten metal can be maintained at a specific level. This is important in applications that require precise temperature control, such as in metallurgy and materials processing.
4. What factors besides induction coil current can affect the temperature of molten metal?
Other factors that can affect the temperature of molten metal include the type and composition of the metal, the size and shape of the crucible or container, and the ambient temperature. These factors should be taken into consideration when determining the appropriate induction coil current to achieve the desired molten metal temperature.
5. Is there a maximum temperature that can be reached by adjusting the induction coil current?
Yes, there is a maximum temperature that can be reached by adjusting the induction coil current. This is known as the Curie temperature, which is the temperature at which a material loses its magnetic properties. Beyond this temperature, the induction coil current will no longer have an effect on the molten metal temperature. The Curie temperature varies depending on the type of metal being heated.
  • Classical Physics
  • Electrical Engineering
  • Materials and Chemical Engineering
