gracy
- 2,486
- 83
Am i right?Bystander said:Draw a line from the point at one end through the toothpick to the point at the other; strictly speaking that is the "major" axis.
The rolling of toothpick is similar to my the moment of inertia of a molecule about the bond axis and because we are multiplying square of half of diameter (in the order of 10-30m2)with masses of pea.so it's value reaches nearly zero.Bystander said:No. No. No.
I will give you a toothpick. You will stick one baby green pea on one end and a second baby green pea on the other end. The bond length is the length of the toothpick, or the distance between the peas. The peas are the two atomic nuclei in the diatomic molecule. Lay it on the table in front of you. You can spin it on the table (horizontal plane) around the center of the toothpick (the point midway between the peas), or you can roll it as if the toothpick were an axle and the peas were little bitty tires, or you can rotate it in a vertical plane about the center of the toothpick. These are the three axes of rotation. The moments of inertia for rotation in either the horizontal or vertical planes are calculated by squaring the distances of the peas from the center of the toothpick, multiplying the squares by the masses of the peas and adding them. The moment of inertia for rolling the toothpick is calculated by finding how far the peas are from the axis of the toothpick, and that is at most only half the diameter of the peas (the toothpick is stuck through them), squaring that distance and multiplying by the masses of the peas.
You do NOT square one distance for one moment and multiply it by the square of another distance for a different moment.
gracy said:The rolling of toothpick is similar to my the moment of inertia of a molecule about the bond axis and because we are multiplying square of half of diameter (in the order of 10-30m2)with masses of pea.so it's value reaches nearly zero.right.?That's what my original question was.
Ok last questionBystander said:Yes.
This is same as motion in xz plane i.e perpendicular or about to y axis.Bystander said:Lay it on the table in front of you. You can spin it on the table (horizontal plane) around the center of the toothpick (the point midway between the peas)
This is same as motion in xy plane i.e perpendicular to or about z axis.Bystander said:or you can rotate it in a vertical plane about the center of the toothpick.
Ok.Now it's finally my last question.Just a tiny doubt.What about rolling case?isn't it same as motion in yz plane i.e about or perpendicular to x axis. .According to your 17 post i don't think so.how x.axis differ from bond axis?just that bond axis passes from center of mass and x-axis doesn't?If we take toothpick example ,how would motion in yz plane look like?Bystander said:You got it.
Wait.I think i have figured it out.motion in YZ plane would be same as ingracy said:Ok.Now it's finally my last question.Just a tiny doubt.What about rolling case?isn't it same as motion in yz plane i.e about or perpendicular to x axis. .According to your 17 post i don't think so.how x.axis differ from bond axis?just that bond axis passes from center of mass and x-axis doesn't?If we take toothpick example ,how would motion in yz plane look like?
Just instead of horizontal plane it would be vertical plane.Right?Bystander said:Lay it on the table in front of you. You can spin it on the table (horizontal plane) around the center of the toothpick (the point midway between the peas),
Thanks a lot.You helped me a lot.I must say You are truly homework helper and science advisor but not a Bystander,you totally got involved in my problem.Thanks again.Bystander said:Yup.
Actually i got the answer which i have asked in my original post but i am stuck on a point.The video which i have posted in my post 42 from time 3:15 to 3:30 and in this videogracy said:Thanks a lot.You helped me a lot.I must say You are truly homework helper and science advisor but not a Bystander,you totally got involved in my problem.Thanks again.
... consider: there are an infinite number of axes that are not the bond axes.they should include. As x-axis is not same as bond axis
But how can i assume this?this is what my question is difference between bond axis and x axis.Simon Bridge said:let the x-axis be the bond axis
It is the same. We agreed it's the same. It's not considered in the videos because the angular moment of inertia about it is insignificantly small due to the dimensions of the nuclei --- remember? Square 10-15m and compare it to the square of 10-10m? It's one 10 billionth the magnitude of the other two moments.gracy said:As x-axis is not same as bond axis.Please reply.It's my humble request.
That's what i wanted to listen.Now i am having no doubt.It completes this thread.Bystander said:It is the same.
... you are free to call the bond axis anything you like. If you don't like "x" how about "y" or "z" (z is a very popular choice because: cylindrical coordinates)... or "bob" or "kate" or anything you like. It's just a bit of shorthand.gracy said:But how can i assume this?this is what my question is difference between bond axis and x axis.
