Moment of inertia spinning disk integration
The discussion focuses on calculating the moment of inertia of a spinning disk through integration, specifically using the equation I = ∫r^2dm. The user initially sets up the integration limits incorrectly and confuses the variables, leading to an incorrect result of (PI/2)R^4 instead of the expected (PI/4)R^4. After receiving feedback, they realize the limits of integration for r should be from 0 to R, not 0 to 2R, and correct their approach. Ultimately, the user identifies that their mistake stemmed from unnecessary substitutions and misunderstandings of variable constants. The correct integration process yields the accurate moment of inertia for the disk.
ShamelessGit
I want to calculate the moment of inertia of a spinning disk via integration. I'm aware of the perpedicular axis theorem, but I want to integrate.
I = ∫r^2dm
if I set my coordinate axis op so that the origin of the xy plane lies in the center of my disk, and I decide to rotate the disk about the x axis, then I figure r in this case is equal to y and I integrate along the x-axis from -R to R.
So I set up ∫∫y^2dydx, which I can change to ∫∫r*y^2drdθ. y = rsin(θ), so
∫∫r^3*sin(θ)^2drdθ, where the limits of integration are 0< r < 2R (R = max radius), 0 < θ < 2PI
I look up the integral of sin(x) and I get x/2 - sin(2x), so I think my answer to this integral should be (PI/2)R^4. Of course the answer should be (PI/4)R^4. I don't understand what I did wrong. I think I know how to integrate so I assume something is wrong with my set-up.
Hi ShamelessGit! :smile:
(try using the X2 button just above the Reply box :wink:)
no, 0 < r < R :wink:
not following this :confused:
can you show your working?​
(btw, learn your trigonometric identities … sin2x = (1 - cos2x)/2, which is easier! :smile:)
I made a typo when I was giving the limits of integration. The way I set it up the limit of integration for r should be -r to r.
And also I figured out that when I integrate properly, I do get the right answer.
The mistake I made was that I changed y to sqrt(R^2-x^2) in my original calculation before realizing that that was unnecessary, and when I changed it back I got r*R^2 instead of r^3 because I got confused about which R was a constant and which was a variable. So I got R to the right power, but of course I got a factor of 1/2 instead of 1/4.
I made a type when trying to fix the previous typo. Yes the limit is only from 0 to r. Srry about that. I didn't make that mistake on the paper when I was actually trying to integrate
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
