Moment vector expression to magnitude of moment
The discussion focuses on finding the magnitude and angle of a moment vector given as moment = -2.8i - 1.53j + 2.24k. Participants clarify that the magnitude of a vector can be calculated by squaring each component, summing them, and taking the square root. There is confusion regarding the use of trigonometric functions to determine angles, with one participant noting that the inverse tangent of the vectors does not yield accurate results. The conversation emphasizes the importance of correctly applying vector magnitude formulas. Overall, the thread highlights common challenges in vector calculations and the need for clarity in solving such problems.
kleeds
find the magnitude and angle of the moment
moment=-2.8i-1.53j+2.24k
force tension=2.4 kN
rxf=rfsin(theta)
i used the cross product to get i j and k
tried sin and cos of vectors but didnt work.
inverse tan of vectors won't give close to correct angles
Welcome to PF!
As far I as I can tell, the first part of the question is simply asking what the magnitude of the given vector is. You have all three components of the vector.
What is the expression for the magnitude of a vector in terms of its components?
I have no idea. The last time i did vectors at least six months ago.
nevermind you square them all, add them, then take the square root.
Yeah.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
