Moments - How are they actually calculated?
  • Thread starter Thread starter 012anonymousx
    Moments
Moments are calculated using the perpendicular component of the force relative to the axis of rotation, multiplied by the distance from the pivot point. The parallel component of the force does not contribute to the moment since it has a zero perpendicular distance. Mathematically, the moment is expressed as the cross product of the position vector and the force vector. The magnitude of the moment can be calculated using the formula l = rf*sin(θ), where θ is the angle between the position and force vectors. Understanding this distinction is crucial for accurate moment calculations.
012anonymousx
Moments -- How are they actually calculated?
Hello, I have a question.
Is the moment calculated:
Force times the distance or
Force's perpendicular component (to axis) times the distance.
For example, let's say I have a stick.
Pulling on it is not moment.
So if I push at the stick to an angle, the way I calculate the force that the other side is applying is by taking the perpendicular component of my Fa and multiplying it by the distance.
Is that correct?
Yes, when you are calculating moments, you would use the perpendicular component. The parallel component will not produce any moment as the perpendicular distance is zero.
Likes 1 person
Mathematically, a moment is ##\vec{l} = \vec{r} \times \vec{f}##. The magnitude comes out as ##l = rf\sin\theta##, where ##\theta## is the angle between the position vector and the force vector. This is equivalent to saying that it is the perpendicular component of the force.
Likes 1 person
Thank you!
Thread ''splain this hydrostatic paradox in tiny words'
This is (ostensibly) not a trick shot or video*. The scale was balanced before any blue water was added. 550mL of blue water was added to the left side. only 60mL of water needed to be added to the right side to re-balance the scale. Apparently, the scale will balance when the height of the two columns is equal. The left side of the scale only feels the weight of the column above the lower "tail" of the funnel (i.e. 60mL). So where does the weight of the remaining (550-60=) 490mL go...
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
