Moments of Inertia of two particles
The problem involves calculating the moment of inertia of a system consisting of two particles and a circular disk, with the system rotating about a point A. The moment of inertia for the disk was initially calculated incorrectly, as it should account for the disk's mass of 4m and the correct axis of rotation. The correct approach involves first determining the moment of inertia about the center of mass and then applying the parallel axis theorem to find the moment of inertia about point A. The user is advised to correct their initial calculations and compare results from both methods for accuracy. Understanding the correct mass and axis is crucial for solving the problem correctly.
Spaceflea
Two particles, each of mass m, are attached one to each end of a diameter PQ of a uniform circular disk, of mass 4m, radius a with its centre at O. The system is free to rotate about a horizontal axis through A, a point on PQ such that OA = b as indicated in the diagram below. The system is released from rest when PQ is horizontal.[/B]
Determine the Moment of Inertia of the system about the axis A, in terms of integer constants, a , b and m.
I=ma^2
parallel axis equation I=Icentre of mass + md^2
I have determined the moment of inertia of the disc to be 0.5ma^2.
I have determined the moment of inertia of Q to be m(b+a)^2.
I have determined the moment of inertia of P to be m(a-b)^2.
Therefore I should just add these three numbers together to make a total moment of inertia, but this answer is marked wrong (it is marked by a computer programme). Where am I going wrong in my method? Thanks.
That's the generic formula for a circular disk about its center. You'll have to modify it.
These are OK.
Your expression for the moment of inertia of the disk is incorrect: You have the wrong mass and the wrong axis.
Correct that, and your method should work fine.
Another approach would be to find the moment of inertia of the entire system about its center of mass, then use the parallel axis theorem. Do it both ways and compare!
Thanks so much for the reply! But I am confused over which axis and mass I should use instead. Obviously not point A...
I assume you are talking about the disk? What's the mass of the disk? You need its moment of inertia about point A, but don't start there. Start with the moment of inertia about the center of mass and use the parallel axis theorem.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
