Momentum/Conservation of energy
  • Thread starter Thread starter Danielle_6
    Energy
The discussion revolves around a physics problem involving momentum and energy conservation during a collision between two individuals, Fred and Brutus. Fred, weighing 50 kg, runs at 6.10 m/s, while Brutus, weighing 130 kg, approaches at 5.10 m/s. After colliding, they fall and slide on the ground, with the coefficient of kinetic friction given as 0.330. Participants emphasize the importance of applying the kinetic energy formula and understanding the relationship between force and friction to solve the problem. Engaging with the problem and making an initial attempt is encouraged for effective assistance.
Danielle_6
Fred (mass 50.0 kg) is running with the football at a speed of 6.10 m/s when he is met head-on by Brutus (mass 130 kg), who is moving at 5.10 m/s. Brutus grabs Fred in a tight grip, and they fall to the ground. How far do they slide?The coefficient of kinetic friction between football uniforms and Astroturf is 0.330 .
Danielle_6,
You got to try something before we can help you. At least a guess. What is the formula for kinetic energy? How does force relate to coefficient of kinetic friction? TRY!
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
