Momentum eigenfunctions in an infinite well
In summary: There is no limit in theory to the magnitude of momentum that a particle could have.And the maximum value of momentum in Newtonian physics is ...?Yes ; it is infinite but it seems strange to come across such a simple example of incompatibility between QM and SRYes ; it is infinite but it seems strange to come across such a simple example of incompatibility between QM and SR
dyn
773
62
Hi
For an infinite well , solving the Schrodinger equation gives wavefunctions of the form sin(nπx/L). These are not eigenfunctions of the momentum operator which means there are no eigenvalues of the momentum operator. Does this mean momentum cannot be measured ?
Inside the infinite well the Hamiltonian is p2/(2m) ; this commutes with p so that should mean that momentum and energy share common eigenfunctions but as i stated above there are no momentum eigenfunctions. Where am i going wrong ?
Thanks
Yes in the well but it is zero outside. That matters.
It is superposition of various mometum eigenstates, the coefficiets of which provide probability to observe specific momentum value by product with complex conjugate.
Yes inside but it includes no zero potential energy outside. That matters.
Likes topsquark
Have you tried looking for momentum eigenstates? Note that momentum is a vector and that any momentum eigenstate ought to be an energy eigenstate, but not vice versa.
Likes Vanadium 50 and topsquark
In free space system of zero potential energy everywhere, yes.
Likes topsquark and PeroK
In the case of an infinite well, the momentum operator is not self-adjoint.
Likes hutchphd, mattt, topsquark and 1 other person
This is a very good question. The answer is surprising, but only at first sight: There is no momentum-observable for particle in the infinitely high potential pot, because the operator ##\hat{p}=-\mathrm{i} \hbar \partial_x## is not self-adjoint on the interval ##[0,a]##. We had this discussion some times in the forum. Here's one answer
https://www.physicsforums.com/threa...the-infinite-square-well.1004624/post-6509638
Some nice, didactic papers on self-adjointness are
https://arxiv.org/abs/quant-ph/9907069
https://arxiv.org/abs/quant-ph/0103153
Likes curious_mind, topsquark, weirdoguy and 2 others
vanhees71 said:
This is a very good question. The answer is surprising, but only at first sight: There is no momentum-observable for particle in the infinitely high potential pot, because the operator p^=−iℏ∂x is not self-adjoint on the interval [0,a].
For this exercise for the biginners I prefer observing what happens in finite well potential V system in the limit of ##V \rightarrow \infty## to discussing mathematical subject of ##V = \infty##. We may keep the interval ##[-\infty,+\infty]## and apply usual Fourier transform method to get momentum wave function.
e.g. mometum wave function, Particle in a box wiki https://en.wikipedia.org/wiki/Particle_in_a_box
Likes vanhees71 and topsquark
You got some mathy answers. You can also use your physical intution:
(1) If I solve the time-independent Schroedinger Equation, I ghet energy eigenstates, which tale the from E-p2/2m. You could then say, [itex]p = \pm \sqrt{2mE}[/itex] which obviously has two values.
(2) These two values correspond to the particle moving to the left and moving to the right.
(3) But these solutions cannot be good for all time, because eventually the particle will hit the well boundary. So they can't be solutions of the time-independent Schroedinger Equation: they aren't time-independent.
Therefore, there are no solutions.
Likes Nugatory, PeroK, malawi_glenn and 1 other person
My complement
A classical perfect reflection analogue of
[tex]\alpha|p'>+\beta|-p'>[/tex]
where
[tex]p'=\sqrt{2mE'}[/tex]
isn't a solution neither.
Thanks for all your replies. Before i go any further , i need to ask ; is a state of definite momentum the same as a momentum eigenfunction ?
Each mometum eigenfunction has eigenvalue which is a definite value of momentum of the state.
To make a wavefunction that has the form sin( nπx/L) inside the infinite well and is zero outside the well requires a continuous superposition of momentum eigenfunctions performed using a Fourier transform. Momentum eigenfunctions extend from +∞ to -∞. This means that the wavefunction of a particle confined to a well consists of superpositions of momentum states that extend over all space. That is how i understand it but it seems strange !
On a related note , regarding the continuous momentum basis , the eigenvalue p can take any value in the range -∞ < p < +∞ so in QM infinite momentum is allowed ?
And the maximum momentum in SR is ...?
Likes mattt
As far as i know and my SR is very rusty you can't have infinite momentum in SR
First, you're confusing infinite with having no limit. You can't have infinite momentum in any physics, as infinity is not a number. But, there is no limit in theory to the magnitude of momentum that a particle could have.
You're wrong about SR.
Likes mattt
I know a particle's velocity can't exceed c so i would presume there is also a limit on momentum
You presume wrong.
Likes Vanadium 50
Relativistic momentum approaches infinity as u approaches c but u can never equal c so momentum can never be infinite
  • Skeptical
Likes PeroK
Just like in Newtonian mechanics because v also cannot be infinite.
Likes mattt and PeroK
Why can v not be infinite in Newtonian mechanics ?
  • Skeptical
Likes mattt, Vanadium 50 and PeroK
Because infinity is not a number. It can be as big as you want, but always finite.
Likes mattt
For an example in a harmonic oscillator energy eigenstate, position x and momentum p both have Gaussian probability distributions around zero. We have tiny but not zero probality to observe any large p as well as x.
If a particle is the origin and moving at infinite speed, where is it one second later?
A parade of false statements, hoping to be corrected, is a poor way to learn.
Irrespective of the quality of the argument, why would one be surprised that non-relativistic QM is non-relativistic? That's like being surprised that Burfer King sells burgers,
  • Haha
Likes mattt
In Newtonian Mechanics p=m*v and p can be as high as you want because v can be as high as you want.
In Relativistic Mechanics p=m(v)*v and p can be as high as you want because m(v)=mo/sqrt(1-(v/c)^2) is as high as you want if v is close enough to c.
I would not call them burgers tbh... garbage at best :)
Likes Motore
You spelt Burger incorrectly ! Actually i was hoping to not be corrected. Are you telling me that in QM , CM and SR there is no limit on how big momentum can be ? Surely v not being able to reach c places a limit on momentum in SR
  • Sad
Likes PeroK
You've already been told that this is not correct...
  • Skeptical
Likes Rev. Cheeseman
  • #31
Yes, that's what they have told you.
Instead of waving your hands, do the math. If you have questions about the math, you can start a new thread in the appropriate forum. This thread is closed as the question you asked in your OP has been answered.
Likes PeroK
  • #32
It does not.
The momentum of a particle moving at speed ##v## is ##p=mv/\sqrt{1-(v^2/c^2)}##.
That value can be made as large as we please by choosing a value of ##v## sufficiently close to but still less than ##c##.
Likes dyn and PeroK
FAQ: Momentum eigenfunctions in an infinite well
What is a momentum eigenfunction in the context of an infinite well?
A momentum eigenfunction in the context of an infinite well is a wavefunction that satisfies the eigenvalue equation for the momentum operator. In an infinite potential well, the particle's wavefunction must satisfy the boundary conditions of the well, and the momentum eigenfunctions are typically complex exponentials that represent a definite momentum state.
How are momentum eigenfunctions related to the energy eigenfunctions in an infinite well?
In an infinite well, the energy eigenfunctions are sinusoidal functions (sines and cosines) that satisfy the boundary conditions of the well. Momentum eigenfunctions, on the other hand, are typically complex exponentials. The energy eigenfunctions can be expressed as a superposition of momentum eigenfunctions, reflecting the fact that a particle in a well has a quantized set of allowed energy levels and corresponding momenta.
Why are momentum eigenfunctions not typically used as the primary basis in an infinite well?
Momentum eigenfunctions are not typically used as the primary basis in an infinite well because the boundary conditions of the infinite well impose constraints that are more naturally satisfied by standing wave solutions (sinusoidal functions). These standing wave solutions correspond to the energy eigenfunctions, which are easier to work with when solving problems related to the infinite well.
Can momentum eigenfunctions be normalized in an infinite well?
Yes, momentum eigenfunctions can be normalized in an infinite well. However, due to the boundary conditions, the normalization process involves ensuring that the wavefunctions are orthogonal and normalized over the finite region of the well. This often involves integrating the complex exponentials over the well's length and applying the appropriate normalization constants.
How do boundary conditions affect the form of momentum eigenfunctions in an infinite well?
The boundary conditions of an infinite well require that the wavefunction vanishes at the walls of the well. This constraint means that the momentum eigenfunctions must be constructed in such a way that they satisfy these conditions. Typically, this results in a discrete set of allowed momenta corresponding to the quantized energy levels, and the momentum eigenfunctions are often expressed as a combination of sine and cosine functions that satisfy the boundary conditions.
