I Momentum of a Water Jet Impacting Plate
In the scenario of a fluid jet impacting a stationary plate, momentum is not conserved due to the influence of external forces. The vertical force from gravity and the plate alters the fluid's momentum during the impact. After the impact, the total momentum of the fluid is zero in the reference frame of the plate, as the radial velocities cancel out symmetrically. The reasoning highlights that momentum conservation depends on the absence of external forces acting on the system. Thus, the fluid's momentum changes due to these external influences throughout the event.
person123
TL;DR Summary
When a jet impacts a plate, is the momentum of the fluid conserved?
Suppose you have a jet of fluid (say water) traveling vertically upward at a constant velocity. It impacts a stationary horizontal plate and so moves radially outward in all directions. Assume that there's no energy loss during the impact, so the speed of the fluid remains constant. Is momentum of the fluid conserved, and what is the total momentum of the fluid after impact?
I believe the momentum is not conserved, since the fluid changes directions. The vertical downward force of the plate leads to a net change in momentum of the fluid. This is even in an ideal scenario without energy loss. I also believe the total momentum of the fluid after the impact is 0 (in the reference frame of the stationary plate). The total radial velocity would add up to 0 since it's symmetric. Alternatively, since there's no horizontal force, the horizontal momentum must remain 0, and the vertical momentum must be 0 as well since there's no vertical motion of the fluid after impact. Is my reasoning correct?
(For context for why I'm asking, I'm TAing a lab where this question was asked, and every group answered momentum is conserved or it's not conserved just because of frictional loss, so I want to make sure my reasoning is correct).
If the fluid alone is the system, its momentum is not conserved because external forces are acting on it throughout the event you describe:
  1. As soon as the fluid emerges from the nozzle and until it hits the plate, the external force of gravity acts on it and, therefore, its momentum is not conserved.
  2. During the fluid's collision with the plate, the external force of the plate acts on it and, therefore, its momentum is not conserved.
There is only one criterion for determining whether momentum is conserved: whether an external force acts on the system or not. It follows that when two balls collide, the momentum of either ball is not conserved, but the momentum of the two-ball system is.
Likes person123 and berkeman
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
