Monotonic sequence definition of Continuity of a function
In summary: N## such that:$$|x_k - x_0| < \delta ~ \text{but} ~ |f(x_k) f(x_0)| \geq \varepsilon"The proof is just bad. You're like 50% of the way there conceptually but the terrible notation doesn't string together in a way that gets you close.
Hall
351
88
Main body
Main body.
Question: There is a function ##f##, it is given that for every monotonic sequence ##(x_n) \to x_0##, where ##x_n, x_0 \in dom(f)##, implies ##f(x_n) \to f(x_0)##. Prove that ##f## is continuous at ##x_0##
Proof: Assume that ##f## is discontinuous at ##x_0##. That means for any sequence ##(x_n)##, in ##dom(f)##, converging to ##x_0## we don't have ## \lim f(x_n) = f(x_0)##, symbolicallyFor every N there exists, at least one, ##k > N## such that
Doubt 1: I haven't said anything about ##\delta## and ##\varepsilon## before, and simply introduced them to mean the difference is small,is this how we do it formally?
Now, as for every ##N## we have "a" ##k## satisfying those properties, therefore, we have all those ##k## forming a subset of ##\mathcal{N}## like thus
k_1 > N_1 ~~\text{satisfying those properrties}$$
$$k_2 > N_2 > k_1 ~~ \text{satisfying those properties}$$
##\vdots ##
$$k_i > N_i > k_{i-1}$$
##\vdots##
and hence, ##(x_k)## is a sub-sequence of ##(x_n)##, and
$$\lim (x_k) \to x_0$$
##\since## for every ##x_k## we have ##|f(x_k) - f(x_0)| \geq \varepsilon##, but ##(x_k)## is a monotone sequence and we must have ##|f(x_k) - f(x_0)| < \varepsilon##
This contradiction has arisen because our assumption that ##f## was discontinuous was wrong.
Doubt #2: Is what I have done correct?
No, it means that for some sequence ##(x_n)##, in ##dom(f)##, converging to ##x_0## we don't have ## \lim f(x_n) = f(x_0)##.
Likes Hall
Yes, I can see it.
It doesn't bring down my proof, right? Or am I missing something else?
The biggest issue: why is thy sequence you constructed at the end monotone?
You should start with this, using the sequence definition of convergence. If it's not clear why what I'm writing below is true, start by proving it (it's equivalent to saying ##f## is continuous when for all sequences ##x_n\to x_0## we have ##f(x_n)\to f(x_0)##)
if ##f## it's discontinuous at ##x_0## then there exists ##\epsilon>0## and a sequence ##x_n\to x_0## such that for all ##N>0##, there exists ##k>N## such that ##|f(x_k)-f(x_0)| >\epsilon##
I guess you mean ##k_1 \lt k_2 \lt k_3 \lt \cdots k_i \cdots \lt ## doesn't imply
x_{k_1} \lt x_{k_2} \lt x_{k_3} \cdots
I agree with you.
Let me mend the proof (Someone there is that doesn't love the proof):
As for each ##N## we have a ##k## such that ##x_k## follows those two things, we have a whole sequence of those points as ##(x_k)## (in actuality a subsequence of ##(x_n)##).
As from any sequence we can extract a monotone sequence, let's say ##(x_{k_i})## is a monotone sub-sequence of ##(x_k)##. We have, ## x_{k_i} \to x_0##, but ##|f (x_{k_i} ) -f(x_0) | \geq \varepsilon##. That is, though ##(x_{k_i}## is a monotone sequence and converges to ##x_0## but ##\lim f(x_{k_i}) \neq f(x_0)##. This is in pure contradiction with the given statement.
Thus, the given statement implies continuity of ##f##.
No. You need to introduce and quantify the ##\epsilon## and ##\delta## in some way. In this case, I think you are using them in a proof by contradiction, so you are assuming the function is discontinuous. You should say something like, "There exists an ## \epsilon \gt 0## such that ## \forall \delta \gt 0 ## and for each N ..."
The way you know ##|x_k-x_0|## is small is because ##k>N##, and ##N## is arbitrarily big. There's no independent picking ##\delta## here.
Likes FactChecker
You have to also change "for any sequence ##(x_n)##" to "there exists a sequence ##(x_n)##", and then describe the properties of that sequence consistent with your assumption that the function is discontinuous at ##x_0##.
I have got another doubt which I think doesn't demand a new thread.
Problem statement:
Let f be a real-valued function whose domain is a subset of R. Show f is continuous at x_0 in dom(f) if and only if, for every sequence (x_n) in dom(f) \ {x0} converging to x0, we have lim f(x_n) = f(x0).
Solution: I'm a little confused here as of what difference ##dom (f) - \{x_0\}## will make because we always put ##0 \lt |x_n - x_0| \lt \delta##, thus, in itself signifying that ##x_n## never gets ##x_0## in a ##\delta-## neighbourhood, yes, but, the possibility that it becomes equal to ##x_0## outside ##\delta## is still there, but why do care? We're only interested in ##\delta-## neighbourhood.
However, here is the proof:
(Forward implication): Given that ##f## is continuous at ##x_0##, we have, by definition:
"for each ##epsilon \gt 0## there exists a ##\delta \gt 0## such that
0 \lt |x - x_0| \lt \delta \implies |f(x) - f(x_0)| \lt \epsilon"
Consider a sequence ##(x_n)## converging to ##x_0##, with the property that
x _n \neq x_0 ~~~~~~~~\textrm{for all n}
For every ##\delta \gt 0##, we have an ##N## such that
n \gt N \implies |x_n - x_0| \delta \implies |f(x_n) - f(x_0)| \lt \epsilon
Thus, ##\lim f(x_n) = f(x_0)##.
(backward implication): Given that for every sequence ##(x_n) \to x_0## with the property that ##x_n \neq x_0## for all n, implies ##\lim f(x_n) = f(x_0)##.
Assume, that ##f## is discontinuous at ##x_0##, that is in each ##\delta-## neighbourhood of ##x_0## there is an ##x## such that
\begin{equation*}
| f(x) - f(x_0) | \geq \varepsilon
\end{equation*}
So, for a particular sequence ##x_n = x_0 - \frac{1}{n}## (and it satisfies both the qualifications of our given statement) we have for a sufficiently large ##N##
\begin{align*}
n \gt N \implies 0 \lt |x_n - x_0| \lt \delta \\
\textrm{but} ~~~ |f(x_n) - f(x_0)| \geq \varepsilon \\
\end{align*}
for some ##x##, thus, ##\lim (x_n) = x_0## but ##\lim f(x_n) \neq f(x_0)##. But this contradicts our given statement. Thus, ##f## is continuous at ##x_0##.
I mean nowhere I could see any importance of "##(x_n)~\textrm{ in}~ dom(f)-\{x_0\}##".
A general comment I have is that your understanding is ok, but you are not correctly using the official definitions. You need to be more careful about that.
Problem statement:
Is ##0 \lt## in your official definition? It is not enough to say "we always put". You have to use your official definition. Of course, an infinite sequence of ##x_0##s do "converge" to ##x_0## but that sequence is not helpful in defining continuity.
No. You have to use your official definition. That is in terms of "there exists a ##\delta##", not ##N##. In this step of your proof, you have to use the existence of ##\delta## to show that ##N## exists.
\begin{equation*}
\end{equation*}
Where did this ##\epsilon## come from? You have said nothing about it, but now it suddenly appears. What property does it have?
Likes Hall
Yes, the official definition doesn't say ## 0\lt |x-x_0| \lt \delta##
Let ##f## be a real-valued function whose domain is a subset of R.Then ##f## is continuous at ##x_0## in dom(f) if and only if for each ##\epsilon \gt 0## there exists δ>0 such that x ∈dom(f) and $$
|x−x_0|<δ \implies |f(x)−f(x_0)| < \epsilon
$$I will, I think, benefit more if I shall be given a model proof.
Most introductory textbooks would have several of them. This is a PDF with a couple of examples. (I don't know if the link will download a PDF or not)
Likes Hall
FAQ: Monotonic sequence definition of Continuity of a function
What is a monotonic sequence?
A monotonic sequence is a sequence of numbers that either consistently increases or decreases. In other words, every term in the sequence is either larger or smaller than the previous term.
How is a monotonic sequence related to continuity of a function?
A monotonic sequence is important in understanding the continuity of a function because it helps determine if a function is continuous or not. If a function has a monotonic sequence, it is more likely to be continuous.
What is the definition of continuity of a function?
The definition of continuity of a function is that the limit of the function at a given point is equal to the value of the function at that point. In other words, there are no sudden jumps or breaks in the graph of the function.
How does a monotonic sequence affect the continuity of a function?
A monotonic sequence can affect the continuity of a function in two ways. If a function has a monotonic sequence, it is more likely to be continuous. On the other hand, if a function does not have a monotonic sequence, it is more likely to have points of discontinuity.
Can a function be continuous without a monotonic sequence?
Yes, a function can be continuous without a monotonic sequence. A function can have a non-monotonic sequence and still be continuous as long as there are no sudden jumps or breaks in the graph of the function. However, having a monotonic sequence can make it easier to determine the continuity of a function.
