fluidistic
- 265
I am learning about the use of Monte Carlo to calculate/estimate uncertainties. If I take the example of a single measurement (i.e. I measure several quantities required to get an estimate of some physical property, but I do this only once), I can use Monte Carlo and some common sense for the inputs of the method. I provide the probability distributions of each variables (most of them as Gaussians for example, some as uniform over some interval, some as triangular, etc.), and I get a histogram of the physical property I want to "measure" or calculate from the measured data. Generally this histogram is not a Gaussian, it could be more like a log-normal for example.
According to the GUM (section 7.6, page 29 https://www.bipm.org/utils/common/documents/jcgm/JCGM_101_2008_E.pdf), one should report the mean and the standard deviation of the obtained histogram, as uncertainty associated to the physical property which I want to "measure"/calculate. I fail to understand why would one report the mean and the standard deviation instead of the median and the 68.3 (1 sigma for a Gaussian) confidence level interval. Wouldn't the latter give much more information about the "true" value of the physical property I am looking for? More precisely, wouldn't this give me a more probable value than the mean and SD would?
I have seen some papers (including one published in Nature) where they do not explicitely state what they report, but it looks like the median and the 68.3 CLI to me, which would make more sense than what the GUM suggests. But, I am almost sure, the GUM has the last word, so the mean and the SD should be reported. This would give no information about the skewness, I am not sure about its advantage(s) over the mean and the CLI.
